Should I match LSi's with RT's?
Hello. I'm looking to buy the LSiFX surrounds and match it with RT models (surround backs and mains). It looks like the LSi's are an older model. Should I be matching these two model types together or shoudl I be looking at something newer than the LSi's?
Post edited by florad on
You should be looking at the RTi line. The LSi will sound totally different than the RT line and the 4-ohm nominal rating can really stress out receivers.
Stick to the RT line unless you plan on going LSi all the way in the future.
Maurice
