Soldering station or iron recommendations
Emlyn
Considering doing some soldering at home for repairs and modifications to some things, and plan on getting fairly serious about it, so I want to get my own gear for soldering. Looking for recommendations what's the best cost/performance wise today and something that will last for the long term. Suggestions? How about this from Weller?
Partsexpress
Partsexpress
Post edited by Emlyn on
This is the one I have...and it's perfect for everything including Cardas products. Go industrial.
WELLER WTCPTCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
dorokusai wrote:This is the one I have...and it's perfect for everything including Cardas products. Go industrial.
WELLER WTCPT
I too also own one of those WTCPT had it for years.... Top end Weller all the way.
Doro Telco guys must think a like. :eek:
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
another nod for weller. I use one on my rc stuff and it works greatMatthew
Sometimes the road less traveled is less traveled for a reason
HT
Yamaha RX-V2500
CS400-Center
SDA 1A-Mains
RT20-Surround
None right now-Rears
SVS 20-39PCi
Infocus IN72 -
WELLER WTCPT
I like it. Hardcore!
One of the most painful things I've ever done (as a teenager), was grab a Weller from the wrong end. Self branding sucks.
I agree weller! I use a weller WSD 81, lots of tips to choose from. http://www.tessco.com/products/displayProductInfo.do?itemId=176400
So far I like this station best. I got it about 2 mo ago & It to me is better than my old wtcpt. The pencil on the 81 is skinner & fits better in my hand especially when its a bigger job. I use the station for electronic repairs, a/v repairs & hobby. couldnt be happier. Myu station is used 6 days a week. -
If I could find the irons my dad has from when he was a field service tech, I'd say to use those but I don't think they are made anymore. That said, Weller may not be the absolute best out there but they are very good pieces of equipment and they have several heads that can be interchanged for different soldering needs. That also has an adjustable temperature control which is important especially when working with printed circuit boards like what is found in some crossovers. It can seem a little pricey at ~$145 but you can be pretty much rest assured that you will not need another one for a very long time. That would not be a bad buy in any respect. The other bonus is that IIRC, it comes with hardware to mount it to the work bench which is a good safety measure.Expert Moron Extraordinaire
Emlyn wrote:
I have used this iron at a friends house. It is just ok. Doesn't feel real good, gets hot on the handle but works. I am used to using the ones at work (like Doro has). Actually I have one at home I like even better for audio stuff and it is cheaper in price. I'll get the number off of it.
Mine at home is an Ungar 921ZX but unfortunatly it is out of production. I chose it because our re-work person liked it much better for fine stuff. You really can't beat the one Doro recommended if you want to pay that much. I think you could get by with the cheapy though.
The one from Parts Express is good as a starter. Nice for soldering wires, and if you get a smaller tip, good for through hole parts.
The one that Doro recommends is what we use at work (well, other than our super duper surface mount soldering station). Great all around station and they last forever.Brian Knauss
ex-Electrical Engineer for Polk -
Great suggestions and advice. Thanks. I knew I asked in the right place.
Looks like I'll probably be getting the Weller WTCPT. The WSD 81 is probably more than I'd need for occasional use rather than every day use, and I'd likely end up eventually having to replace the lower powered type if I got one of those. -
Mark - Let me look up the price thru work, I may be able to get it cheaper for you.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I dropped by Fry's today and found that there was a WTCPT inside their locked cage with a sticker printed $104.99!!! Real? I had to run but will check it out later this week. If so, sounds like a good deal.
-fredv- -
It is real, same price at outpost:
http://shop3.outpost.com/product/1723113?site=sr:SEARCH:MAIN_RSLT_PG
-fredv- -
dorokusai wrote:Mark - Let me look up the price thru work, I may be able to get it cheaper for you.
Thanks Mark. That would be outstanding.
Fred, the price from Fry's does look great too. -
Just found this one, also has a fume filter...
Soldering Station w/ integrated Fume Extractor (456DLX)SYSTEM
HDTV ..........Sony KP-57WV600
CD / DVD......Sony DVP-C675D
AVR ............Denon 2801
MAINS .........Polk RTi8
CENTER .......Polk CSi5
Surrounds ....Polk FXi3
Sub ............Polk PSW-250
Cables.........Zebra Cables -
What's the fun in soldering all day and not having that terrible smell right under your nose for the rest of the day? That and fiberglass resin are two of those smells that just stick around with you for an entire day.Brian Knauss
You're not supposed to burn the resin.Expert Moron Extraordinaire
Hai your soldering recomendation topic is very useful.
Soldering station other recomendation.
This is what i use:
http://www.mcmelectronics.com/product/WELLER-WLC100-/21-3475SRT For Life; SDA Forever!
The SRT SEISMIC System:
Four main satellite speakers, six powered subs, two dedicated for LFE channel, two center speakers for over/under screen placement and three Control Centers. Amaze your friends, terrorize your neighbors, seize the audio bragging rights for your state. Go ahead, buy it; you only go around once. -
Another vote for the Weller WTCPT. I prefered it when it was made in the USA though.
Greg
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
I bought this Hakko soldering station in June. I've used it for some speaker updates I've done, and it seems to be pretty good. It has a 5 star rating at Amazon.
http://www.amazon.com/Hakko-Soldering-Station-936-Iron/dp/B000ARU9HWSunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
Weller is good, but this is an EXCELLENT soldering station for under $50:
Circuit Specialists
Name Code Qty Each Options
Soldering Station with SR-976N 1 41.95
Ceramic Heater (SR-976N)
Soldering Station with 976T-SB 1 4.95
Ceramic Heater (SR-976N):
Extra Tip - 0.3mm
Soldering Station with 976T-BC 1 4.95
Extra Tip - 1.0mm
Soldering Station with 976T-4C 1 4.95
Extra Tip - 4.0mm
Subtotal 56.80
Shipping 9.40
Tax 0.00
Total 66.20TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer
