PolkBar
NeilGabriel
Please save me from searching several hundred posts....
Is there a SoundBar that is simply a speaker where you can use your own dvd player and amplification?
Trying to help out kids who have small apt but a PS3 and a small HTR.
Post edited by NeilGabriel on
amplification? meaning you already have a receiver? then the passive 'Surroundbar' and 'Surroundbar 50' are what your looking for
(if you want something super simple that already has its own amplification and thus does not need a receiver, then check out the upcomming Surroundbar 6000 for surround sound or the cheaper Surroundbar 3000 for basic audio upgrade) -
What are prices on these? Will they need stands or can they sit in front of the HDTV? Thanks. -
Polk Provides you with both cradle and wall mounting options (both SBs).NeilGabriel wrote: »What are prices on these? Will they need stands or can they sit in front of the HDTV? Thanks.
MSRPs: http://checkout.polkaudio.com/basket.asp but I am convinced you can get good deals at your favorite BM store. Perhaps check Polk ebay store?Accessories (comes with) 2 piece wall bracket, center channel base, 25' wire bundle, and the Quick Start GuideDARE TO SOAR:
