Leaving amps on
sda2mike
sda2mike Posts: 3,131
edited November 2010 in 2 Channel Audio
so....do you leave your power amp on..all the time, all weekend or only when you're listening??? your opinions, please;)
thanks
mike
Post edited by sda2mike on
    EndersShadow Posts: 17,705
    edited September 2010
    sda2mike wrote: »
    thanks
    mike
    I leave both my reciever and amp on 247. No issues yet w/ the amp, reciever had issues, but they are apparently quite common (HDMI HDCP handshake issues).
  • fishbones
    fishbones Posts: 947
    hey hey, another Florida Polkie!!
    Well, I can tell you that my stuff stays unplugged whenever not listening, cause I don't need to tell you how it is with lightning down here in south Florida. Surge protectors will only stop so much, and in the 20 yrs I've lived here, I've had 2 direct hits to homes I've lived in! :eek:
    ...my 2 cents
  • steveinaz
    steveinaz Posts: 19,545
    My Parasound is like a space heater, so, no. It only takes about 10mins to come up to temp/max performance.
  • sda2mike
    fishbones wrote: »
    ...my 2 cents
    luckily, i'm in a very stable grid...the next town over tho, is notorious for outages and surges
    heiney9 Posts: 25,445
    http://www.polkaudio.com/forums/showthread.php?t=56387
    http://www.polkaudio.com/forums/showthread.php?t=51351
    My Aleph 30 will raise the room temp by about 4-6* over a 3 day period along with my preamp and now the dac puts out a little bit of heat as well. Leaving my rig powered up in the summer makes for a toasty listening room. The winter isn't so bad.
    All my gear powered up has an idle draw of about 500W so I try not to leave it on if I know I won't be listening for a few days. Ironically it takes 3-6 hours for it to sound the best. Especially the Aleph which doesn't reach full operating temp until about 2 hours in.
    I typically leave the gear on unless I know I won't be listening on a regualr basis simply because of heat and current draw at idle.
  • steveinaz
    Another way to "cheat" if you don't like the idea of everything staying powered up, is make sure the first few CD's you throw in are of really good sound quality...that's the trick I use. Usually after the first CD, my Parasound is up to speed.
    I know, I'm sick right?
  • Ricardo
    Ricardo Posts: 10,636
    I use a similar approach but using wine. After the first two glasses, everything sounds great!!
    SOPA
    steveinaz wrote: »
    I don't get it?
    With the Aleph the first 60 minutes sound dark, closed in, narrow soundstage and at that magical 60 minute mark everything opens up, midrange become more liquid and the highs are simply wonderful. It hits full speed about 6 hours in.
    No amount of great sounding cd's can fix that. But of course it's different for all gear, etc.
    Ricardo wrote: »
    For me it's Vodka Martini's or Tequila.
  • cstmar01
    cstmar01 Posts: 4,424
    Normally I don't leave mine on. When I do listen its normally Friday night through Sunday and I'll power up my stuff on Friday morning to get it rolling from there and then shut everything down Sunday night and unplug seeing I would rather do so if there was a storm that rolls through when I'm not around ect.
  • DaveHo
    DaveHo Posts: 3,583
    +1 on the room heat gain thing. When I had cooler running equipment, it was left on 24/7. At one point I'd say the amp for the front 3 was on for nearly 4-5 years straight, minus vacations & other times when I'd be away for more than a day or two. The Aragon amps I have now generate way too much heat to be on all the time.
    -Dave
  • Ricardo
    I have a Tequila bottle here waiting for a special ocassion. Maybe next Thursday...but then we won't get to Polkfest too early.....
    SOPA
  • Willow
    Willow Posts: 11,233
    my amps are on all the time, except if we travel, then I turn them off.
  • steveinaz
    heiney9 wrote: »
    I don't get it?
    It's a matter of relativity. Cold equipment + poor sounding CD = awful; Cold equipment + great sounding CD = not too bad.
    In reality, my Parasound doesn't take long at all to get up to speed--and never sounds bad.
    steveinaz wrote: »
    Ah, that's what I was thinking but then I thought maybe there was more to it.
  • sda2mike
    i noticed last night...the last 45 min or so of a 2+ hour session: it was really sounding fkn good! every aspect..maybe especially down low..and little layers of stuff that normally goes un-noticed..horns sound more hornish and pianoes...yeah you get it:D
    my wife just does not get it...i like it like that:)
    If my gear is off I always plan around having to turn it on an hour or more before I sit down and listen. I rarely just power up and then sit down and listen.
  • cfrizz
    cfrizz Posts: 13,415
    I leave it on. But my amp goes into standby mode when not in use.
  • cstmar01
    If I was drunk and listening I could be playing the latest single from Cher and I would think its good....
    well I would have to be very very drunk...
    but otherwise when things warm up it does sound better I think, and I think more so with tube stuff.
  • sda2mike
    heiney9 wrote: »
    that's a good plan...i did that last night - not on purpose..i think it helped w the enjoyment factor
    sda2mike wrote: »
    If I'm not too busy on the weekends I usually turn the rig on Thursday night and leave it powered up through Sunday unless I'm going to be out a lot over those days. During the week I'm finding harder and harder to find time to listen or I'm listening to 1 of 3 tube amps in the office/computer rig while I putz around in there. Those take about 30-60 minutes to reach full operating as well.
  • dorokusai
    dorokusai Posts: 25,576
    I usually leave my amplifier on if I know I'll be listening within the next 24 hours, otherwise, I shut everything down. I believe that my rig sounds better when everything is warmed up.
    I've also not been disappointed in the sound on the fly, depending on the company. If it's a critical listener, I would take better steps but if its just a regular individual...its simply not neccesary. Most ppl that just think audio is cool don't require a lot of prep and its easy to sound awesome.
  • FTGV
    FTGV Posts: 3,650
  • megasat16
    megasat16 Posts: 3,521
    All my stuff takes about 5 minutes to warm up, properly biased and ready to R&R.
    I'd be broke to leave any of my stuff on for 24 hours before listening. :D:eek:
    Having said that, I sometimes left my preamp on for a day or two coz I am so lazy to push the button. :eek:
    Trying out Different Audio Cables is a Religious Affair. You don't discuss it with anyone. :redface::biggrin:
  • cokewithvanilla
    cokewithvanilla Posts: 1,777
    I have wondered about this for a while. I know my GFA-5800 takes a long time to get warm, so I've left it and my preamp on for the last two days. I think it has totally improved my sound. I usually have short listening sessions so I think it is a good idea for me to keep them on... we'll see what happens with the next electric bill.
  • Ern Dog
    Ern Dog Posts: 2,237
    I typically like to listen to my rig when I'm showering and getting ready every morning and then again in the evening. I turn my rig off when not in use.
  • zingo
    zingo Posts: 11,258
    My SET tubes get turned on about 1 hour before I listen to them, but it's not realist to leave them on 24/7 because of the heat/power consumption/tube life.
  • PSOVLSK
    PSOVLSK Posts: 5,384
    On 24/7 unless out of town, etc.
  • FTGV
    FTGV Posts: 3,650
    zingo wrote: »
    it's not realistic to leave them on 24/7 because of the heat/power consumption/tube life.
    Yeah you would'nt want to burn through B300's and the like too quickly.
  • FTGV
    FTGV Posts: 3,650
    FTGV wrote: »
    Yeah you would'nt want to burn through 300B's and the like too quickly.
    fixed:D
