Anti vibration isolator
acmf74
Has anyone use these before? If so what is your expereince with them?
Thanks,
http://cgi.ebay.com/10-ANTI-VIBRATION-ISOLATOR-PADS-2X2X7-8-HVAC-/130423943754?pt=LH_DefaultDomain_0&hash=item1e5ddf724a
Thanks,
Post edited by acmf74 on
There was a thread last month about using them with success. I believe they are available from Grainger and other supply stores for a good price. Check with them to see if it is similar pricing to your ebay list.
Quest for sound has the same ones (by the picture) for 25 bucks for 4 of them and 5 dollars shipping. They work and are great.
Noob question - but I have to ask - what do you use these for? put them under subs / speakers to dampen room vibrations?Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
We had these posted on the site for awhile. I wanna say the guy is a Polkie or very familiar with us and may offer a little discount. Someone can check me on that, but much nicer
http://avrisers.com/default.aspxShoot the jumper.....................BALLIN.............!!!!!
The AV Risers to me wouldn't seem to absorb as much as the rubber and cork isolators. They are a great product, but seem to be more riser than isolator.
I just ordered some of these and they will be arriving tomorrow. I will be trying them for the first time. We'll see how they do. Mapleshade also sells them at a higher mark up.
I found them for .25 cents each + $10 shipping from here: http://www.pexsupply.com/DiversiTech-MP-2C-Rubber-Cork-Anti-Vibration-Pad-2-x-2-x-7-8 -
Thank you!
