I bought a yaqin mc10l today
polkfarmboy
polkfarmboy Posts: 5,703
edited September 2010 in Electronics
Silly question but what do you have to do a setup a tube amp?
I have heard the bias word but dont have a clue what it means
Will I have to buy some kinda volt meter for this bias?
Post edited by polkfarmboy on
«13
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    Yes, you will need a voltmeter.
    Did you buy the latest version where the bias adjustments are on the outside?
    SDA SRS 2.3TL's
    SDA 2B TL's
    heiney9 Posts: 25,445
    Also if it's new do NOT trust that it came from the factory biased properly. If you bought it used I wouldn't believe the previous owner either unless you get the sense in corresponding with him that he does know what he's doing and set it properly.
    I listened to the previous owner of one of my tube amps when he said the bias didn't need to be adjusted and I ended up burning out a tube up. The tube was not a cheap Chinese tube either, but a fairly expensive 50's RCA 6V6 blackplate that was part of a matched quad of power tubes.
    Also never power up a tube amp without a load hooked up, meaning speakers. You can damage the transformers if you run a tube amp with out speakers hooked up or if you're familiar with electronics you can configure a "dummy" load in place of the speakers. Sometimes this is easier when you want to bias a tube amp. In your case if you bought the newer version it won;t be necessary to make a dummy load because accessing the bias points are easy.
    One of my tube amps needs to biased from the bottom with the bottom plate removed. Meaning I have to turn it upside down and rest it on the tube cage to make bias measurements and adjustments. I'd say when it's new check the bias initially maybe once a week for a month and after that perhaps every 6 months depending on use. Always check the bias when rolling tubes and adjust accordingly.
    One of the nice things about a manual bias amp is it's not necessary to buy power tubes that are closely matched because you can set the bias for each individual tube. A fixed bias amp needs to use closely matched tubes for best performance because there is no way to compensate for tubes that aren't matched.
    In the end this can mean buying tubes to roll is cheaper since a closely matched quad or pair usually is more expensive. Of course it doesn't hurt to get them all matched if you're not paying a premium to do so.
  • polkfarmboy
    my tube amps being deliverd today and my wife doesnt know it!!!! lol
  • zingo
    zingo Posts: 11,258
    Your amp should come with biasing instructions and how-to, and posting pictures can let us help you out better. It's a pretty easy process, and it makes amps more fun and interactive for me. Good luck!
  • polkfarmboy
    tnx Z
    I will post pics as soon as the ups guy drops it off and have you guys to help me through it
    Even though its not a million dollar amp I'm still very excited to have a listen .Tube amps are sexy looking so its gona be awesome to have it sitting out on my rack
  • steveinaz
    steveinaz Posts: 19,545
    You can't post pics cause the wife don't know yet, huh?...LOL Kidding man, I kid because I care.
  • michaeljhsda2
    The instructions that came with my MC-10L are very brief, however, biasing the amp is very simple. Attach speakers to the amp and power the amp on. After a few minutes check V1 first. The reading should be between 350 to 400 millivolts. Then check V2, V3 and V4. Use the supplied allen wrench to make adjustments. Turning the allen wrench clockwise increases the voltage. It doesn't take much of a turn, perhaps an 1/8 of a turn, to get a change in voltage. The front 4 tubes do not get biased.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • polkfarmboy
    steveinaz wrote: »
    I took a holiday today and the wifes on her lunch break right now so I'm frieking out incase the door goes get a loud knock from the ups guy holding a package lol
    She'l be gone in 25 minutes and it seems like hours .I'm sweating like a ****
  • steveinaz
    Married men all over this great country know your pain, and sympathize. Might I suggest reminding her how much you love her?
  • zingo
    zingo Posts: 11,258
    Send it to your work; Problem solved. :D
  • polkfarmboy
    All clear !! The enemy has left the target zone
  • polkfarmboy
    The slinky fox is in the hole lol
    Nice sturdy packaging foam with treasure inside
  • zingo
    zingo Posts: 11,258
    Looks good! What will you be powering with it? Does it come with a remote?
  • polkfarmboy
  • zingo
    zingo Posts: 11,258
    Yaqin makes good looking products.
  • polkfarmboy
    Tubes came nice and secure inside plastic pvc pipe...I remember being told no touching the tubes with bare fingers......am all excited here guys:)
  • polkfarmboy
    :eek: The yaqin doesnt have an instuction manual and all I have is this sh*ty volt meter
  • michaeljhsda2
    What's the ohm rating on your speakers?
    SDA SRS 2.3TL's
    SDA 2B TL's
  • polkfarmboy
    To test it I will be using 8ohm polks rti8 for starters then when I'm confident with it being setup I will be using my 6 ohm martin logan source
  • michaeljhsda2
    For the ML's the 4 ohm taps might sound better but try it on the 4 and the 8 ohm and see if you can tell any diff. I use the 4 ohm taps on the SDA 1C's and the 8 ohm taps for the 1.2TL's.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • polkfarmboy
    I'm scared that I might bust the connectors for the tubes .....do you have to realy force them down?
  • nikolas812
    nikolas812 Posts: 2,915
    Yeah. A little. There virgins at this point. They'll loosen up over time.;)
    Nik
  • polkfarmboy
    Well everythings hooked up ....should I power it up or do I have to check stuff with the volt meter?
  • polkfarmboy
    :D Wow !!!!!!!!!!!!!!! This aint even broken in yet and I can just tell its got way more authority than the onkyo 607 lol(obviously) . I feel that my reciever has robbed me of my audio childhood
    The yaqin started up wierd ....Just clicked into my head that the tubes warm up:):D:D:D:D:D:D:D:D
    Holy **** .....Theres so much slam as Ive gone through some tecno music
  • michaeljhsda2
    That was my reaction when I had it running the 1.2TL's. :) I'm really impressed with these amps.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • michaeljhsda2
    Shuguang EL34's come with the newest version of the Yaqin MC-10L...not a bad tube at all IMO. One day I might replace them with the Shuguang Treasure series. I did replace the 6N1's with NOS Russian military 6N1P's but I haven't noticed any improvement or degradation in sound quality.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • zingo
    zingo Posts: 11,258
    Looks like we have another believer, and I may have to consider buying the 300B Yaqin amp... I've only heard good things about their line-up so far.
    Congrats on the great amp! How's the biasing coming?
  • zingo
    zingo Posts: 11,258
    Shuguang tubes are pretty decent tubes, and the best of the Chinese stock tubes that I've found. I was real happy with my old EL34 amp leaving the Shuguang output EL34 and swapping out the signal tubes.
    The Shuguang Treasure 6CA7-Z tube is a great performer and that whole line of tubes makes me second guess buying popular NOS tubes.
  • michaeljhsda2
    Congrats on the new amp. Glad to hear you're happy with it. Just make sure you are playing her type of music when she walks through the door.
    SDA SRS 2.3TL's
    SDA 2B TL's
