Added a pair of Audioquest King Cobras
kevhed72
kevhed72 Posts: 5,146
I recently added a pair of these between my CDP and AVR. I previously was using a pair of AQ Sidewinders, and I consider the King Cobras a pretty nice upgrade. The biggest gains I noticed were a more defined bass guitar on many songs, and the soundstage seems to have widened a bit.
The one questionable aspect of these ICs is the connections - they are noticeably looser than the Sidewinders. Has anyone else experienced this with higher-end AQ ICs?:confused:
Post edited by kevhed72 on
  • Outfitter03
    Outfitter03 Posts: 563
    edited September 2010
    I originally bought Audioquest Green which I believe is either a custom manufactured product or closeout item as well as copperbacks from HCM Audio. Both of these products have a nice tight fit. They have a solder based RCA connector with copper Pins.
    I now also have a set of AQ Diamondback connectors that I run from AVR to Amp and they are very loose as you described. They are the "Ultrasonic" soldered units with the Silver connectors. Sound pretty good but fall off easily.
    I wish I would have had the spare cash and timing to pick up those MIT S3 that Mole sold yesterday. Would like to compare a set of MIT with these AQ before I go further up the food chain.
  • sm88
    sm88 Posts: 353
    I've been looking to pick up some King Cobras, I have the Black Mamba's which use the same sort of plug but are not cold welded, don't have the silver drain wire, and use a different geometry (same copper though). Also curious on your thoughts of MIT so please post a review when you get them, I am 1000% skeptical of their design, but I have an open mind so impressions would be appreciated!
    Current System:
    Paradigm Signature S2 v2
    Conrad Johnson MF2500
    Wyred4Sound DAC2
    Audioquest Black Mamba II
    For Sale:
    3x Wilson Cub's
    tonyb Posts: 33,072
    Your skeptical of MIT's design ??
    Look around the board,use the search, plenty of threads of MIT owners and comments on the sound. Yes they are a premier brand but upgrades in SQ can be had at much cheaper levels too.
  • sm88
    sm88 Posts: 353
    tonyb wrote: »
    I've also read about an audio show where a blind test of MIT against home depot zip cord was indistinguishable, but there are always opinions on both sides of the fence. I suppose "i'll believe it when I hear it" is the best approach for me, i'll have to pick up some MIT and give them a try.
    There were three sets I believe of Terminator 3 IC's locally a little while ago for like $50 but I found them to be an older model and passed.. can you help me out with the different "levels" of MIT? I'd be looking mid range, around $150-200 new
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • kawizx9r
    kawizx9r Posts: 5,150
    Mole had a pair of MIT S3's for sale? When? :confused:
    I just sold a pair yesterday.
    sm88 wrote: »
    I wasn't able to compare a pair of King Cobra's or Mambas but I posted a thread last year reviewing AQ's Scarlet Vipers (audioadvisor exclusive), AQ Sidewinders, Ben's Silver IC's (which I'm told are better than the AQ's you mentioned owning) as well as a pair of MIT Shotgun S3's (that I had the pleasure of borrowing even though they were in a different league than the above cables).
    Since then, I turned to MIT S3's and never looked back. I'd rather stick with them rather than go back to AQ, just my .02 if it means anything to ya.
    The thread can be found if you look up threads I've started.
    -Freddy
    Edit: Here's the thread - http://www.polkaudio.com/forums/showthread.php?t=92264
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • sm88
    sm88 Posts: 353
    Thanks, once I get a DAC and Tube Pre i'll look into the S3's
    Current System:
    Wyred4Sound DAC2
    For Sale:
    3x Wilson Cub's
  • Outfitter03
    Sorry kawizx9r it was you not Mole' and at one heck of a price too. Makes trying out some MIT's affordable as they would resell quickly at that price if one did not like them.
    In all my shopping they have been over $300.00 and if they show up on here, one must be quick as lightening to snag them.
  • Outfitter03
    Thanks for the link. That seals the deal for me that I must try at least one pair of the S3's before trying anything else.
  • Polkitup2
    Polkitup2 Posts: 1,642
    kevhed72 wrote: »
    I had the Audioquest Diamondbacks and also noticed that they were slightly loose on my gear. A decent sounding cable but I prefer the locking connections on my MIT cables.
  • michaeljhsda2
    michaeljhsda2 Posts: 2,201
    My King Cobras are not as snug as I would like them to be but they do stay connected.
    SDA SRS 2.3TL's
    SDA 2B TL's
  • kevhed72
    Well, at least it isn't just me. Seems odd for a higher end cable, unless it is by design. Oh well, its the sound that matters in the end:)
