Klipsch Forte II
iskandam
I have a pair of Klipsch Forte II in oak oil for sale for $400. I did the following tweaks on them:
* Dynamat on the woofer and passive radiator baskets
* Replaced stock gasket tape with Mortite
* Wrapped both midrange and tweeter horns with Mortite
* Lined the inside of the speaker cabinet with asphalt paper
I've always wanted to do these tweaks ever since reading about the improvements all you SDA owners experienced. They are very time consuming to do, but the results speak for themselves -- improved bass resolution, better imaging, increased clarity, and smoother midrange and highs.
In the interest of full disclosure, there is a burn mark on top of one of the speakers and a few minor nicks on the cabinets. Other than that the cabinets are in good condition.
Due to the size this will have to be a local sale in the Los Angeles area.
Post edited by iskandam on
Location?HT setup
Panasonic 50" TH-50PZ80U
Denon DBP-1610
Monster HTS 1650
Carver A400X :cool:
MIT Exp 3 Speaker Wire
Kef 104/2
URC MX-780 Remote
Sonos Play 1
Living Room
63 inch Samsung PN63C800YF
Polk Surroundbar 3000
Samsung BD-C7900 -
40 miles east of Los Angeles
SPECS:
FREQUENCY RESPONSE 32Hz-20kHz(+-)3dB
POWER HANDLING 100 watts maximum continuous (500 watts peak)
SENSITIVITY 99dB @ 1watt/1meter
MAX ACOUSTIC OUTPUT 119dB SPL
NOMINAL IMPEDANCE 8 ohms
CROSSOVER FREQUENCY HF 7,000 Hz
LF 650 Hz
MAXIMUM ACOUSTIC OUTPUT 119dB SPL
TWEETER K-75-K 1" (2.54cm) Polymer diaphragm compression driver
HIGH FREQUENCY HORN 90(o)x40(o) Exponential Horn
MIDRANGE K-61-K 1.5" (3.81cm) Phenolic diaphragm compression driver
MID FREQUENCY HORN 90(o)x40(o) Tractrix(r) Horn
WOOFER K-25-K 12" (30.48cm) Fiber-composite cone active / KD-15 15" (38.1cm) Fiber-composite cone passive
ENCLOSURE MATERIAL Medium density fiberboard construction (MDF)
ENCLOSURE TYPE Bass reflex via passive radiator
DIMENSIONS 35.4" (89.92cm) x 16.5" (41.9cm) x 12.25" (31.1cm)
WEIGHT 67 lbs. (30.42kg) -- This pair weighs more because of the mortite wrap around the midrange/tweeter horns and asphalt paper lining the interior of the cabinet
FINISHES Walnut Oil, Oak Oil, Oak Clear, Finished Black
BUILT FROM 1989
BUILT UNTIL 1996 -
sold
Damn!!
Nice speakers..
Good deal...
I sold mine and upgraded to the Cornwalls.HT Theater
SRS-SDA 2.3tl RDO's
Custom Center made out of a RTA15tl
Pioneer Elite SC-25 Receiver
CineNova Grande 5 channel Amp
Klipsch KA-1000-THX Sub Amp
(2)Klipsch KW-120-THX Subs
Basement System
SRS-SDA 1.2 upgraded Xover
ADCOM GFA 5500
ADCOM GFA 5503
Yahama P7000S Pro Audio Amp
dbx 120x-ds Sub-harmonic Synthesizer
2-JBL 4645C Subs
1-Paradigm SW2200 Sub
Klipsch Reference in wall's -
only selling to upgrade to Chorus II, although to be honest it's not really a night and day difference
