Integrated EL34 Tube Amp - The Commander
zingo
zingo Posts: 11,258
edited September 2010 in For Sale (FS) Classifieds
I am upgrading to an all SET tube based system, so I must say farewell to "The Commander" by Suppo Audio. This EL34 based, 35 watts per channel push-pull vacuum tube amplifier wondering drives everything from Klipsch horns to Polk LSi speakers. It has a great tube sound that is detailed, and a little recessed. This beauty has two RCA inputs, and outputs for 4 and 8 ohm speakers, as well as selectable voltage if you ever need that option. One of the best features of the amp is that the output tube bias is adjustable so that you don't have to use a matched quad of tubes The tube complement is one NOS Telefunken Mazda 12AT7 and a matched pair of NOS GE 6FQ7/6CG7 signal tubes with a quad of Shuguang EL34 output tubes, all sounding great with great life left. The amp also comes with tube dampers for the EL34s and three extra Shuaguang signal tubes for back-ups or tube rolling, and IEC power cord. Even though this amp is only available as a DIY kit from Joe at Suppo Audio, he custom built this one for me, making it exact to his design with excellent build quality. This is the perfect, budget, audiophile integrated tube amp which was made with quality parts including polypropylene capacitors and an ALPS volume pot. Please don't hesitate if you have any questions. $450 plus actual shipping or pick-up
Signal/Noise Ratio: 90db
Frequency Response: 0db 25HZ--50KHZ; -3bd 18HZ--70KHZ
Distortion: 1% @ 35W
Input Sensitivity: 1v
Power Consumption: Max 240w
Weight: 16kg
Post edited by zingo on
