Integrated EL34 Tube Amp - The Commander
zingo
I am upgrading to an all SET tube based system, so I must say farewell to "The Commander" by Suppo Audio. This EL34 based, 35 watts per channel push-pull vacuum tube amplifier wondering drives everything from Klipsch horns to Polk LSi speakers. It has a great tube sound that is detailed, and a little recessed. This beauty has two RCA inputs, and outputs for 4 and 8 ohm speakers, as well as selectable voltage if you ever need that option. One of the best features of the amp is that the output tube bias is adjustable so that you don't have to use a matched quad of tubes The tube complement is one NOS Telefunken Mazda 12AT7 and a matched pair of NOS GE 6FQ7/6CG7 signal tubes with a quad of Shuguang EL34 output tubes, all sounding great with great life left. The amp also comes with tube dampers for the EL34s and three extra Shuaguang signal tubes for back-ups or tube rolling, and IEC power cord. Even though this amp is only available as a DIY kit from Joe at Suppo Audio, he custom built this one for me, making it exact to his design with excellent build quality. This is the perfect, budget, audiophile integrated tube amp which was made with quality parts including polypropylene capacitors and an ALPS volume pot. Please don't hesitate if you have any questions. $450 plus actual shipping or pick-up
Signal/Noise Ratio: 90db
Frequency Response: 0db 25HZ--50KHZ; -3bd 18HZ--70KHZ
Distortion: 1% @ 35W
Input Sensitivity: 1v
Power Consumption: Max 240w
Weight: 16kg
Weight: 16kg
Post edited by zingo on
Now thats an inexpensive way to jump into tubes.It appears to have some hefty output trannies.EL 34 midrange sweetness.Somebody needs to jump on this--I bought a little headphone tube amp from Z,,and I cannot get it away from my wife--bump for a good guy and a very easy way to get into tubes.Good luck with the sale.JC approves....he told me so. (F-1 nut)
Is this the Silver or Plat. edition?
It is a beautiful amp. -
It started as the Silver Edition, but then I upgraded to a NOS Telefunken Mazda 12AT7 and a matched pair of NOS GE 6FQ7/6CG7. The output tubes are still the stock Shuguang standard EL34s, but the improvement in sound quality is stunning with just the swap of the new signal tubes.
Very Interesting amp, looks cool as well. So it"s a integrated?MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
That gear reminds me a bit of CJ stuff...just the fascia portion. Cool piece.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Congrats to buyer and seller.
Congrats that is a sweet amp!
Conradicles wrote: »Congrats that is a sweet amp!
Thank you sir! I'm hoping that your speakers and the Commander will become great freinds!? Doing this purchase instead of seperates, should leave enough room to finally get a seperate DAC.
fishbones, that Jolida 100A CD Player that Scott has for sale here has your name on it.
haha, too funny - I saw that, I'm turning into mole here with all the gear I'm buying up around here
....but I think, that a seperate DAC with my PD65 would be a better combo than the Jolida CDP alone? But, I am just assuming....? That is a nice looking player! ..... ><////(*> -
You may be correct...
I also have my Primare player available I'd be willing to give you a heck of a bundle deal Troy.
Thanks, but I do like my PD65. My goal at this time would be just to add the DAC...... ><////(*> -
