Computer Virus Kicked My **** :-(
24
  • exalted512
    exalted512 Posts: 10,735
    edited September 2010
    Windows isnt installed on my other hard drive. Its just the files.
    Say you have a windows 7 OS install disc and you saved it to a hard drive...thats what I have.
    I havent even had time to mess with it today. Might not have time til tonight or tomorrow. So could i change the boot order in bios and run it from the hard drive or should i just save it to a disc and run it from that?
    Id rather not have to save it to disc if i can run it from the hard drive...i just dont know if thats possible
    -Cody
  • exalted512
    Sorry for the derail Cody . . . I know you're not having an easy time with this problem but you post above cracked me up.
    Fixed! LOL!
    BTW PM Sal or John, I'm sure they will get you fixed up in no time, perhaps they will even talk you through the problem.
    basically! haha.
    Up until that post, the advice i got was:
    1. Dont click on certain stuff on face book (cant get on facebook)
    2. Open up internet explorer and change settings (I dont use internet explorer...and i cant open if i wanted to!)
    3. Start it up in safe mode (Can't! Said that!)
    4. Change your default router passwords
    5. Get a mac (hell no!)
    6. Get linux (still leaves me in my current predicament about uploading an OS when I cant open the one I have right now)
    7. Try it from safe mode (again...)
    8. Try the paid version of Malwarebytes Antimalware (I CANT OPEN FREAKIN WINDOWS!!!!!!!!!!!!!!!!)
    9. Try anti malware (really...REALLY??)
    10. run your anti virus in safe mode also (AAAAAAAHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHHH!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!)
    :D:D:D:D:D:D:D:D:D:D
    -Cody
  • wayne3burk
    wayne3burk Posts: 939
    are you trying to save your files on your hard drive -- if you are.. you can install that hard drive in another bay on another computer... and fetch them
    before you do the nuclear reformatting job
    Yamaha RX-V2700, EMI 711As (front), RCA K-16 (rear), Magnavox Console (Center & TV Stand), Sony SMP-N200 media streamer, Dual 1249 TT =--- Sharp Aquas 60" LCD tellie
  • hearingimpared
    hearingimpared Posts: 21,136
    exalted512 wrote: »
    basically! haha.
    -Cody
    LOL!!! You just have my side splitting!!! I'm glad you can maintain your sense of humor during this. When I spent three days cleaning up the virus on my PC my wife, son and dog were nowhere to be found!:eek::D
  • exalted512
    Viruses don't really bother me. I've never had one before and I know I can just reinstall windows and get rid of it. I made a stupid mistake and paid for it. I still have my laptop, 2 netbooks, my work laptop...and my temporary roommates desk top I can use. So I'm more than good in the computer department!
    I've taken my hard drive out of the case and put it in a USB hard drive reader thing and got the files I need off of it. What I need now is how to put windows back on when its saved on hard drive and I'll be golden.
    -Cody
  • Refefer
    Refefer Posts: 1,280
    bobman1235 wrote: »
    That's only true if Windows was installed for THAT MACHINE (or at least one very similar). While windows can handle lots of hardware changes, it's not going to come up on a different motherboard than it was originally installed on.
    Windows will boot, it will just complain that all the device drivers are missing. Windows always falls back to generic drivers that are built on spec compatibilities when devices change; after all, it isn't likely to have drivers for a new machine when you initially install it.
    Now, what it will say about the licensing is a different story.
    Lovin that music year after year.
    Main 2 Channel System
    Polk SDA-1B,
    Promitheus Audio TVC SE,
    Rotel RB-980BX,
    OPPO DV-970HD,
    Lite Audio DAC AH,
    IXOS XHA305 Interconnects
    Computer Rig
    Polk SDA CRS+,
    Creek Audio 5350 SE,
    Morrow Audio MA1 Interconnect,
    HRT Music Streamer II
    billbillw Posts: 7,548
    Refefer wrote: »
    My experience has found this to be untrue, except in limited circumstances. Usually, there are many low level drivers that are loaded immediately and will cause a BSOD when you put different hardware in the mix (especially different chipsets).
    If you have the same chipset, you may be able to get away with it.
  • ryanjoachim
    ryanjoachim Posts: 2,046
    If the files are set up properly on your external, you can boot from it and the install will start automatically. If they're not set up properly, you're screwed.
    It's really that simple.
    Get an 8GB flash drive (extremely cheap nowadays). Hook your external up to your laptop and copy all the Win7 files off of it. Go download the Microsoft "Windows 7 USB DVD download tool" and use it to make your flash drive into a boot-able drive. Follow the directions properly and you'll be able to install windows 7 from your USB flash drive.
    MrNightly wrote: »
    "Dr Dunn admitted that his research could also be interpreted as evidence that women are shallower than men. He said: "Let's face it - there's evidence to support it."
    mystik610 wrote: »
    Best Buy is for people who don't know any better. Magnolia is for people who don't know any better and have more money to spend.
    My System:
    TV: SAMSUNG UN55B7000 55" 1080p LED HDTV
    HTPC: Chromecast w/ Plex Media Server. Media streamed from Media Server.
  • Serendipity
    Serendipity Posts: 6,975
    exalted512 wrote: »
    basically! haha.
    Can someone explain how the act of going to a link gets you infected? I thought you had to download something or run a .exe file in order for you to get a virus...
    polkaudio RT35 Bookshelves
    polkaudio 255c-RT Inwalls
    polkaudio DSWPro550WI
    polkaudio XRT12 XM Tuner
    polkaudio RM6750 5.1
    Front projection, 2 channel, car audio... life is good!
  • ryanjoachim
    It's what SHOULD be common sense by now: Don't click on links, and NEVER...EVER...download/run executables from unofficial websites.
    The links themselves do not automatically infect you, but they lead you into situations where you could be fooled into downloading something.
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • hearingimpared
    This is how it happened to me.
    http://www.polkaudio.com/forums/showpost.php?p=1416683&postcount=16
  • Serendipity
    One time there was a pop-up ad that said "Your PC needs critical security updates" with a YES and NO part of the ad. As there was no X button on the top right corner, clicking either YES or NO resulted in malware.
    Effers.
    At least malwarebytes got rid of it...
  • bobman1235
    bobman1235 Posts: 10,822
    If you don't ever run Windows Update or update your browser - and a SHOCKING number of people don't - there are vulnerabilities that leave you open to infection without actually downloading anything.
  • hearingimpared
    bobman1235 wrote: »
    Shoot I have Window Update automatically downloading to my PC almost three times each month it really bogs down the PC when it is downloading in the backround.
  • Serendipity
    I don't know, someone with a Mac running Snow Leopard sent me a virus and when I asked her, she said she didn't send it. So I guess it's possible even for a Mac to pass on viruses - although it didn't directly affect her computer, it somehow managed to get into her contact list and send itself to other people without her consent...
  • ryanjoachim
    EVERY operating system is vulnerable to viruses or things like that.
    Some operating systems are less vulnerable (Linux for example), and others don't have enough of a market share to make writing malware/viruses cost-effective (Apple).
    Just because you hear people say "I've never gotten a virus because I have ***!!", doesn't make them right. Just shake your head and realize that they are living in their fantasy world.
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • exalted512
    I think Steve Jobs makes all the viruses for PCs.
    -Cody
  • hearingimpared
    Sure thing! No one is pist off or jealous of those other OS originators like they are of Bill Gates and Microsoft.
  • wayne3burk
    It's called ActiveX -- imbedded programs in web pages -- flash is a security risk too...
    If you ever get a dialog box in IE or Firefox of Google Chrome or Safari that has buttons for YES NO and CLOSE...
    and if you're slightly paranoid...
    go to task manager and kill the browser process .. all instances of it.
    They can program that dialog box so that whatever button you press will infect your computer with a virus / malware.
    imho
    -- wayne --
  • exalted512
    Sure thing! No one is PIST off or jealous of those other OS originators like they are of Bill Gates and Microsoft.
    your spell check software still sucks!
    -Cody
  • hearingimpared
    exalted512 wrote: »
    -Cody
    LOL! I hit ignore on that! How do you spell pist; hmm pissed, Nah pist is better.:D
  • ryanjoachim
    Pissed
    MrNightly wrote: »
    mystik610 wrote: »
    My System:
  • hearingimpared
    Pissed
    Pist is shorter!:D;) Less keystrokes . . . getting lazy in my old age! LOL!
  • exalted512
    Ok. Now that I've actually had time to play with this...I'm still stuck
    When I downloaded windows from microsoft under the student thing, it downloaded a 'setup' box file and a 'windows marketplace box' file.
    The USB DVD tool thing has to have an iso file. So I downloaded folder2iso and made everything into an iso file and it said its not a valid ISO file. So i tried putting just the windows marketplace box file into a folder by itself and made that into an iso file...still said it wasnt a valid ISO file. Any ideas?
    Thanks!
    -Cody
  • exalted512
    btw, The windows marketplace box file is the one I would click on in if i wanted to install windows by finding the file in my computer and clicking on it.
  • Ric5811
    Ric5811 Posts: 400
    Lost wrote: »
    If you guys would use the paid version of Malwarebytes Antimalware it would eliminate alot of these virus issues...
    +1, plus Avast and Firefox...why anyone uses IE is beyond me.
    I accidently clicked on that link once, not a problem...
    Polk RTi A7's FrontPolk CSi A4 CenterPolk Tsi 100's SurroundOnkyo TX-RZ50:)Oppo BDP 83 (Collecting dust)MIT Terminator 3 Speaker CableMIT Terminator 2 IC's (Oppo 2 chan)Signal Cable HT TWOEpson PowerLite Home Cinema 1080Hisense 55 U8GBelkin PF 60 Power Center
  • hearingimpared
    Ric5811 wrote: »
    +1, plus Avast and Firefox...why anyone uses IE is beyond me.I accidently clicked on that link once, not a problem...
    Maybe because it's free? Are Avast and Firefox free?;)
  • Ric5811
    Ric5811 Posts: 400
    Umm, yes....and I also use the FREE version of malwarebytes..:D
  • hearingimpared
    Ric5811 wrote: »
    CNET, 2cows?:)
    EDIT: Does the free version of malwarebytes bog down the system?
    Sorry again for the derail Cody but I've learned so much from this thread. Perhaps I'll start a separate thread for the PC ancient!
  • Lost
    Lost Posts: 48
    Ric5811 wrote: »
    The free version doesn't have real time protection though. And a one time fee of $25 is well worth it....
