VSX-49TXi on RTI-12's
eswaroop
Hi,
I have a VSX-49TXi receiver paired with RTI-12's. Is that is supposed to be a pretty good unit in terms of driving my tower speakers?
Also, I am in doubt if the receiver is not functioning properly ( power / soundstage / volume wise) - not sure if its the speakers or the amp - bought both used.
Anyone who has the above receiver (which is more suspect) who can help answer a few questions?
A) Is this a good unit to drive the speakers
The idle power consumption on my amp is 375 watts (using kill a watt meter) - is this normal?
C) Is it usual for the unit to heat up to the point where its pretty darn warm to touch?
Thanks,
ES
Thanks,
ES
Post edited by eswaroop on
I have the same reciever and it should drive those speakers. Not sure about the power consumption, but it does tend to get hot."They're always talking about my drinking, but never mention my thirst" Oscar Wilde
Pre-Amp: Anthem AVM 20
Amp: Carver TFM-35
Amp: Rotel RB-870BX
Fronts : SDA 1B w/ RDO-194s
T.V.:Plasma TC-P54G25
Bluray: Oppo BDP-93
Speaker Cables: MIT Terminater
Interconnect Cables:DH Labs Silver Sonic BL-1isonic -
Is the receiver set up properly ? Are you running a sub in the system ? Are you running an amp,if so what kind? Have you checked the speaker wire ? Make sure none of the plastic is caught inside the bidding posts on the speaker,amp. What cables are you using? A tad more info brother if you want some help.HT SYSTEM-
