Best subwoofer cable under $200
What is the best subwoofer cable under $200 for 2 m length?
I am thinking of Kimber Kable Cadence or Audioquest Sub-1.
Any comments, thoughts or suggestions are welcome.
Post edited by deluxman on
2m Cable for $200 :eek:
No wonder Monster is still in business ...Displays - Samsung PN50B860 Panasonic AE900U / Elite Screens 106"
HTPC - Phenom II X3 720 @3GHz / GeminII S cooler 6GB Antec Fusion 2TB Hitachi 7200RPM ATI 4850 / 512MB / Vantec Iceberq 6 cooler Asus Xonar sound card
Speakers - Polk RTi A5 x2 (Fronts) Cambridge Soundworks MC105 x7 (1 - center, 2 - surrounds, 4 - not connected) Cambridge Soundworks 210W 8" Sub
Amp - Cambridge Soundworks 7x70W -
Save your money...here's all you need: http://www.bluejeanscable.com/store/subwoofer/index.htm -
pearsall001 wrote: »Save your money...here's all you need: http://www.bluejeanscable.com/store/subwoofer/index.htm
i have one of those in my bedroom setup.
this and the monoprice ones are both good IMOmole' -
Do you use the RG6 rca cable from Monoprice?
Delux, first understand that although some sellers label a cable as a "subwoofer cable", this is simply a coaxial cable with an RCA plug on each end, and can be used for many audio or video purposes, including hooking up a sub. The mention of $200 for something to serve such a simple function is totally unrealistic. When I got my sub(about $1100)a little over three years ago I got this cable in the 12' length. There's no good reason to spend significantly more than this; more money can't perform a technological miracle.
yup
http://www.monoprice.com/products/product.asp?c_id=102&cp_id=10236&cs_id=1023601&p_id=621&seq=1&format=2mole' -
http://www.amazon.com/Belkin-PureAV-AV50500-25-25-Foot-Subwoofer/dp/B000653HGI
http://www.amazon.com/gp/product/B000653HKY/ref=pd_lpo_k2_dp_sr_1?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B000653HGI&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=12W18FTZ13692AYM4ATZ
I have two of these. Nice cable construction and lot of good reviews. Discontinued item marked way down. -
try knukonceptz I just got the 8 meter cable and it looks well made and has a nice build to it but im still waiting on my new dswpro400 to try it out.
They also have more expensive line 40$ for the 5 meter cable
http://www.knukonceptz.com/productMaster.cfm?category=Subwoofer%20Cable
They are well known in the forums for their car audio cables -
Be hard to beat this one for 20
http://www.buy.com/prod/audiovox-master-series-subwoofer-cable-rca-male-rca-male-25ft-audiovox/q/listingid/46401023/loc/111/90139868.htmlTurntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
I use these
http://www.amazon.com/Monster-Standard-THX-Certified-Subwoofer-Interconnect/dp/B00006RHZG/ref=sr_1_1?ie=UTF8&s=electronics&qid=1283526627&sr=8-1
I know everyone hates monster but for 16 bucks for that length it competes with the other options. Very flexible cable with very very snug connections all around.
