Question about bi-amping/bi-wiring Polk Monitor 70’s with an Onkyo AVR
spock 2054
spock 2054 Posts: 163
edited September 2010 in Speakers
Just for fun, last week I ran the surround back left and right leads from my Onkyo TX-SR806 to the top speaker connectors for the 70’s, front connections still on the bottom, with the jumper removed from both speakers. Set receiver for bi-amp, ran Audessey, and it set the all the speakers (monitor 70’s, CS2, monitor 60’s rear) to full band and my subs to 120. (Setting for the speakers were adjusted to 80hz, but honestly, it sounds better at full band.)
I've been listening for a few days, and I do notice fuller bass and more detailed sound from the front speakers – especially with the subs off. My question is; do you, if you have a similar configuration, notice a slight, great, or no difference in the overall quality of sound from the front speakers when bi-amped/bi-wired with the Onkyo? I think I do notice a tad more detail and bass with more heft to it, but I miss my surround back channels. (jbl e10’s) Just wondering what everyone else has experienced with this configuration. Thanks.
polk monitor 70's
center - polk monitor cs2
surround - polk monitor 60's
surround back - jbl e10
sub - velodyne dps 12
sub - polk psw110
avr/pre-amp - onkyo tx-nr809
amp - adcom gfa-5500
amp - carver av405
display - sharp lc70le847u
tv - silicon dust hd homern
blu-ray - oppo bdp-103
hd dvd- toshiba hd xa2
control - logitech harmony one
turntable - technics sl1500 mkII
Post edited by spock 2054 on
    Congrats....that kind of wiring may or may not do anything and a lot of it is subjective. I bi-amped (technically not real bi-amping since only one amp is involved) M-70s with an equivalent Denon AVR and could not hear a difference. When I added an Adcom-555 into the mix I started to hear a lot of what you describe--though.
    Hey, if you hear it...it's there!
    Enjoy!
    cnh
    EndersShadow Posts: 17,687
    I actually noticed the opposite. I did what you did w/ my Integra DTR 5.9 and thought at first it sounded better. Then when I moved I decided to just go back to single wire's for ease of setup and found more detail that way rather than when bi-wired. Now that I added a dedicated amp (Carver 705x) to the mix I have TONS more detail when listening to music. I havent really tested it out too much w/ movies yet but we will see.
  • cseils
    cseils Posts: 10
    This is interesting because I was thinking about going this route with one of the newer Onkyo AVRs in the future. I noticed they make you use the surround back outputs to bi-wire, do they not bring those back channels over to the other surrounds for a 5.1 setup?
  • spock 2054
    cseils wrote: »
    The surround back channels are gone when you configure your speakers for "bi-amp" mode in the 806 series. The ability to run multichannel analog audio is also not available in bi-amp mode. The main left and right surronds remain active. I went back to a 7.2 configuration - I have a fairly healthy collection of dts 6.1 ES discrete, dolby digital EX DVD's and a multitude of blu-ray and HD DVD titles that use the surround back channel(s).
    polk monitor 70's
    sub - polk psw110
    amp - carver av405
  • Outfitter03
    Outfitter03 Posts: 563
    You may have noticed a difference in sound by using a better connection than the factory jumpers. Upgrading by installing a decent jumper or even good quality speaker wire should improve the quality of your listening as described.
    Did you experiment with simple bi wiring, or does your extra set of speaker cables have the same type of connectors preventing this? Such as both pairs having banana connectors.
    Anti cable makes an affordable set of jumpers http://www.anticables.com/jumpers.html .
    Also there are jumper offered on this site.
    http://www.soniccraft.com/products/connections/jumper.htm
  • cseils
    cseils Posts: 10
    spock 2054 wrote: »
    Guess its intended for 2 channel systems then... bummer. Looks like its back to AVR research for me. Thanks for the info.
  • spock 2054
    cseils wrote: »
    Correction: When you bi-amp/bi-wire, you will still have a 5.1 configuration, just no surround back channel(s).
    polk monitor 70's
    sub - polk psw110
    amp - carver av405
  • PrazVT
    PrazVT Posts: 1,607
    I hesitate to suggest this here (lol), but how about Onkyo's inexpensive M-282 power amp (105w x 2 @ 8ohms)? You could go:
    Onkyo 806 -> first binding post on speakers
    Onkyo 806 pre-outs -> Onkyo M-282 -> second binding post on speakers
    You wouldn't have to turn the bi-amp function on and lose the rear surrounds. My RTi A7s are powered like that - Denon AVR-3311ci (125wpc) to mid/highs and the Onkyo amp to the woofers. Did the same thing w/ the previous Yamaha RX-V663 (95wpc) and it's a significant improvement from using the AVR's internal bi-amp function. The slightly differing power outputs don't seem to affect the sound from what I can tell.
    Anyway, just a 'quick fix' suggestion ... ultimately a dedicated amp is better but depends on your situation. Just my 2 cents :)
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
    +1, real Bi-amping involves two separate amps with separate power supplies--almost NO AVR can really bi-amp anything....even if it uses that terminology. (I say almost NO because there are a few higher end AVRs that have the above requirements).
    cnh
    tonyb Posts: 33,068
    cnh wrote: »
    cnh
    Yeah,what he said.......:D
  • kuntasensei
    kuntasensei Posts: 3,263
    cnh wrote: »
    cnh
    +1. The 806 is already underpowered according to reviews, and since it's drawing power from a common store (and has current limiting in place), it's pointless to do it. If you're hearing a difference, it's more likely that you need better jumpers as Outfitter said.
    But hey, if it works for you, that's all that matters.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
