Interconnect Poll
TORI3
Alright guys (and gals), I need some help in choosing the right interconnects with my system.
Pioneer Elite VSX23
Sunfire Cinema Grand Seven
Polk RTi series
I’m practicing financial responsibility, so I’m starting with only three (fronts and center) interconnects, instead of the standard 5 (RTi4s aren’t connected right now).
I’d consider BJC, but I’ve heard some mix reviews from AVS. With this said, they’re still an option if the consensus points in that direction.
Price range of interconnects: $100 - $200
Distance: 0.5 -- 1.0 meter
*I’m slowly upgrading the system…next will be speakers…
Thanks in advance!
Pioneer Elite VSX23
Polk RTi series
Thanks in advance!
HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8
Post edited by TORI3 on
I voted for Belden,cause they make a good soild product,, but given your budget,why not try some MIT Terminator 2 (grey box).JC approves....he told me so. (F-1 nut)
I have the Black Mamba II's and am impressed with the design, it is similar to a King Cobra, silver plated plugs and the likes, but has a different configuration internally and is cheaper. That said, I only have one short pair and haven't yet outfitted a whole system with them, they were freebies I picked up with a deal.
I'd recommend skipping the purchase of new cables, used is where the deals are at in audio and cables are absolutely no exception. In cases of speakers and the likes, quality issues arise with age, but cables don't really age, so there is no sense paying full price. Do not buy from the bay though unless you are certain of authenticity, and I suggest you filter your results there by "North America" only if you do. Scores of sellers from Hong Kong are peddling cables that lack authentic packaging, but as a lot of the companies plugs are freely available to purchase they look exactly the same as real cables.
The beauty of the scam is that the only way you could really tell a good reproduction from the real deal is to cut one open, which of course damages the very product you just paid for.Current System:
Paradigm Signature S2 v2
Conrad Johnson MF2500
Wyred4Sound DAC2
Audioquest Black Mamba II
For Sale:
3x Wilson Cub's
Conrad Johnson MF2500 -
Haven't heard any of the cables listed but I'd vote for the MIT T2's as well.
Used AQ in the past but since trying MIT, I haven't looked back.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
i have a few Audioquest IC's im not using anymore. sending a PM with more infomole'
Other....+1
Ben's silverSDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM -
george daniel wrote: »I voted for Belden,cause they make a good soild product,, but given your budget,why not try some MIT Terminator 2 (grey box).
From all of the MIT recommendations, I did a quick search, but haven't been able to find much (at least not there entry level stuff). Where online have you guys been purchasing this stuff?I have the Black Mamba II's and am impressed with the design, it is similar to a King Cobra, silver plated plugs and the likes, but has a different configuration internally and is cheaper. That said, I only have one short pair and haven't yet outfitted a whole system with them, they were freebies I picked up with a deal.
THANK YOU!
That's really great insight. You saved me from becoming a sucker!i have a few Audioquest IC's im not using anymore. sending a PM with more info
PM sent.
There's a lot of options up there, but a friend also reminded me of Kimber ICs. I did another quick search, and there seems to be a lot of good reviews on some of their entry level stuff as well.
Thanks for all the great feedback. Much appreciated.HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8 -
Why can't you tell from listening to them? Odd... -
Cable differences are rarely a 'veil being lifted' upgrade in my experience, and if you've never 'heard the authentic cables' in your exact system, how would you ever know beyond the whole "I paid a lot of money for this so it must sound a certain way" philosophy?Current System:
Wyred4Sound DAC2
For Sale:
3x Wilson Cub's
Might be able to.
If you had a pair of the "real deal" sitting there to compare to.
Otherwise.....I don't read the newsssspaperssss because dey aaaallllllllll...... have ugly print.
Ben -
i really like Ben's Silver IC's as well.. I found that I liked Ben's or Kimber Hero IC's (which can be had used for around $100-120) better compared to the AQ Black Mamba II's.
The Black Mamba's seemed a little muddier in the low-end, whereas Bens and the Kimber's were tighter in the low-end. I'm still trying to sort out exact terminology for the mid's and highs, but Ben's seemed brighter than the Mamba's (and I think the Kimber's being more neutral or possibly warmer compared to the Mamba's?)
Bottom line, I had some Mamba's and definitely liked Ben's better then them.. I got some Kimber Hero's and really like them as well, not better than Ben's, but slightly different sound in my setup..
Hopefully thats helpful.. and as a disclaimer I've only heard the above mentioned ICs in my setup
Jason2-Channel - So far...
Pre: Dodd ELP
DAC: W4S-Dac2
Source(s): Computer and Denon 2910
Amp: Parasound HCA-1200II
Speakers: LSi9s - Vr3 Fortress Mod -
FYI... you can get the Oxyfuels for MUCH cheaper than you listed. All "system-dependent" notions aside, I found the Zu's to be stellar in my rig. Comparing against Belden, Audioquest, Signal... and a few others.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
zombie boy 2000 wrote: »FYI... you can get the Oxyfuels for MUCH cheaper than you listed. All "system-dependent" notions aside, I found the Zu's to be stellar in my rig. Comparing against Belden, Audioquest, Signal... and a few others.
Zombie, could you point me in the direction of finding cheaper Oxys?
To be honest, I really like the idea of purchasing cables from the small business. The poll definitely reinforces this feeling, which will make the decision much easier.
Last night I came across a 2002 thread on SignalCable before it became a cult favorite on the Polk forum. Really interesting, here's the link:
http://www.polkaudio.com/forums/showthread.php?t=3380&highlight=Interconnects
Enjoy the read and thanks a ton, guys. Much appreciated!HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
