info on W4S 5 channel amp?
mole'
mole' Posts: 3,160
edited September 2010 in Electronics
mole'
Post edited by mole' on
  • FTGV
    FTGV Posts: 3,650
    edited August 2010
    With rated efficiency >80% then they must be Class D.Most likely ICE modules sourced from B&O like their other models.
  • Face
    Face Posts: 14,340
    edited August 2010
    Yes, I believe they're also ICE powered. Excellent sounding amps, I have two and may be picking up a 3rd soon. Only negative, they're not common ground and will need an A1-A isolation transformer to work with P/B SDA's.
  • SolidSqual
    SolidSqual Posts: 5,218
    edited August 2010
    I have a ST-1000 and ST-250. They are wonderful amps.
  • mole'
    mole' Posts: 3,160
    edited August 2010
    Face wrote: »
    mole'
    nooshinjohn Posts: 26,000
    edited August 2010
    Sunfire to the rescue!!!:D:p
  • mole'
    mole' Posts: 3,160
    edited August 2010
    i see myself getting one of those sooner or later. just have to find a nice higher wpc 5ch.
    mole'
  • Face
    Face Posts: 14,340
    edited August 2010
    In that case, he may as well save some money and get an Emo, they're made by the same people.
    edited August 2010
    Face wrote: »
    If it ain't signed by Bob, it ain't a Sunfire! I don't know who builds them now that Mr. Carver is no longer in charge. I just know that EMO and Sunfire share nothing in common. Carver Digital on the other hand...
  • mole'
    mole' Posts: 3,160
    edited August 2010
    those are PRETTY!!!!
    http://cgi.ebay.com/BOB-CARVERS-SUNFIRE-ETCHED-GLASS-SIGN-PLAQUE-/170443890439?pt=LH_DefaultDomain_0&hash=item27af3f5f07#ht_625wt_911
    mole'
  • Sherardp
    Sherardp Posts: 8,038
    edited August 2010
    I have a D-Sonic IceAmp and love it. Most of the B&O ICE modules are identical with only the chasis being different. Some makers may add small differences here and there but the modules remain the same. Dennis is a great guy to work with and they even customize the amp as you like.
    http://www.d-sonic.net/
  • mole'
    mole' Posts: 3,160
    edited August 2010
    Sherardp wrote: »
    MAGNUM 2000-5 is a nice looking amp. has some power
    3 X 525W / 8Ω 3 front channels
    2 X 250W / 8Ω 2 rear channels
    mole'
  • Face
    Face Posts: 14,340
    edited August 2010
    W4S adds a few tweaks to the ICE modules and an input buffer.
  • cstmar01
    cstmar01 Posts: 4,424
    Face wrote: »
    could you still strap the negatives together or would that not work? probably a stupid question but I had to ask :o
  • Face
    Face Posts: 14,340
    cstmar01 wrote: »
    It's not a stupid question at all. I would contact EJ at Wyred4Sound and ask him, he's usually pretty quick to respond. http://www.wyred4sound.com/contact.html
  • jayman_1975
    jayman_1975 Posts: 672
    I have been seriously looking at getting the STI 500. I am wondering if these amps are warm, bright, mostly neutral?
    Onkyo TX NR 5008 modified by The Upgrade Company
    Oppo BDP 93 modified by The Upgrade Company
    Arcam CD37
    Monitor Audio Gold GS 60
    Revolver Audio Music 5 towers.(surround)
    Vandersteen V2W
  • Face
    Face Posts: 14,340
    I'm running a STI-500 in one of my rigs and I would say it's very neutral.
  • jayman_1975
    Hey face. What have you compared the sti500 to? This will be my first integrated but I'm a little worried that it might not work great with my newly aquired Monitor Audio GS60's which tend to be a little on the bright side.
    Arcam CD37
    Vandersteen V2W
  • Face
    Face Posts: 14,340
    Ah, a McIntosh MC-7270, MC-126, Pass Aleph 5, Aleph 2(?) monos, Ayon Crossfire, couple of misc. chip amps, Manley Stingray, Peachtree Nova, and possibly more.
    IMO, Wyred gear is very neutral, it doesn't add or take anything away. What are you using now and what do you have for a source?
  • jayman_1975
    My source is my oppo bdp83 Nuforce. Arcam av9 pre/pro. Arcam amp. The Arcam stuff is known to match very well with Monitor Audio GS as they are a shade bright and the Arcam is warm. Not sure what characteristic the oppo is throwing into the equation. The STI500 gets rave reviews but it would be a shame if it could not tame the brightness of the GS60
    Arcam CD37
    Vandersteen V2W
  • FTGV
    FTGV Posts: 3,650
    cstmar01 wrote: »
    I know the ASP series of ICE modules have differential outputs so you shouldn't strap the grounds.
  • Face
    Face Posts: 14,340
    If your system is still bright with Arcam gear, I'd look into room treatments, different cables, or go speaker shopping again.
  • jayman_1975
    I don't have the speakers yet they are on their way to me. I guess I might be jumping the gun a little. I was just window shopping for a good integrated and had this one on my short list.
    Arcam CD37
    Vandersteen V2W
