AVR with amp and running speakers from AVR and amp
mole'
mole' Posts: 3,160
edited August 2010 in Electronics
i wanted to know if you have an amp hooked up to an AVR, can you power a set of speakers off of the amp and the AVR at the same time? i mean off of the same channel. i have the pre outs from my AVR hooked up to the amp powering speaker set #1 and wanted to run speaker set #2 off of the AVR front out puts. can i do this or is this just stupid?
mole'
Post edited by mole' on
  • TORI3
    TORI3 Posts: 234
    edited August 2010
    I think I get what you're asking, but just to clarify...
    You have speaker set #1 being powered by the amp (which is using your front preouts), right?
    You also want to use your front speaker channels on your AVR to run the second set of speakers, right?
    Is this correct?
    I've never seen this configuration, so I really don't know if it'll work -- you'd essentially be running two sets of speakers from one set of channels using two separate power sources.
    From my small database of knowledge, you can run your front speakers through the amp via preout from the AVR. Surrounds can be powered by the AVR through the surround channels.
    I'm sure more experienced members will chime in once you clarify.
    Good luck!
    HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
    2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8
  • mole'
    mole' Posts: 3,160
    edited August 2010
    yes that is what im trying to do.
    mole'
  • cnoat
    cnoat Posts: 315
    edited August 2010
    Yes you can.I used to run the upper range on my 12's with the avr and the lower range with the pre outs and the external amp.
    Parasound Avc-1800
    Mains-Rti 12 -Parasound 1500a
    Center-Csi5-Parasound 1000a
    Rears-Rti 8-Parasound 750a
    Sub SVS Ultra Tv 12
    Diamondback and King Cobra IC's
    AQ T4 SC
  • PrazVT
    PrazVT Posts: 1,607
    edited August 2010
    Same - that's how I run my A7s. The Denon runs the mids / highs and the amp runs the woofers. Oddly, the Denon manual (and my Yamaha's manual) both say not to connect speakers to both the pre-outs and the Front speaker terminals at the same time. So I turn on the bi-amp function and connected the speakers to the rear surround (bi-amp) terminals.
    However, I've tried it w/ the front speaker terminals and the pre-outs and it works too. Not sure why the manufacturers don't want us to do it.
    Dali Optikon 1Mk2
    NAD D3020 V2
    Schiit Bifrost 2/64
    ..the rest are headphone setups.
  • mole'
    mole' Posts: 3,160
    edited August 2010
    anyone else have input on this?
    mole'
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited August 2010
    mole' wrote: »
    IMHO most AVRs have this as a selectable option (one or the other) so it should be difficult to use both at once. The possible reason is by internal splitting of the signal, the signal might be to low and the end result could be noise introduced at the output?
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
    edited August 2010
    In most avr's, you can't use both the pre-outs and speaker connections for the same channel. Don't know if that goes for the higher end AVR'S though. Me personally, I wouldn't do it. Can't you just run the other set off of zone 2 ? Or are you trying to get everything off the fronts ? If so, why do you want 2 sets of totally different speakers as the fronts? Just curious is all. That will create one funky sound for sure.:)
    edited August 2010
    Hey my man, just saw your selling your B&K 10, whats the ball park figure ? I didn't see it in the FS section.
  • mole'
    mole' Posts: 3,160
    edited August 2010
    tonyb wrote: »
    PMed.
    i have not posted it yet.
    mole'
  • mole'
    mole' Posts: 3,160
    edited August 2010
    i hooked my Monitors up to my front ch on my AVR and they worked. so i have the 2.3TL's and Monitor 10Bs hooked up as my fronts right now. it does sound good too
    mole'
