SDA interconnect
aloutah
I recently acquired a pair of SDA SRS 1.2's. They did not however come with an interconnect cable. Do any of you have one you are willing to part with? Or know of somewhere I can find one? They come up on ebay from time to time, but usually that is a last resort for me.
Post edited by aloutah on
Have you tried Polk customer service? The one I have was custom made by a local tech. That is always an option also.Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
I havent. I just heard that they werent available, so I never tried them. My first choice is an original SDA interconnect. Thats really what im looking for. If I cant find one, I would also take a custom or aftermarket one.
Anyone have any leads or suggestions on someone who sells custom SDA interconnects, or a 3rd party company making them? For a while there used to be some for sale on ebay that were aftermarket, but (just as i get my first pair of sda's) they seem to have disappeared.
I also have found a few posts on here of people who dont like the SDA effect and use their SDA speakers without the cable. If any of you are reading this, I would be happy to take it off your hands. -
You will need the Pin/Blade for the 1.2's and polk will not have it. You will need to make your own or find a used one...
I actually called back the guy I bought them from and he had found a box of various cables. So last night I went out there. He had some old speaker cable with banana plugs, some other interconnects, and best of all the SDA interconnect cable.
