An HDTV question
madmax
Some of the HD sets I look at have the 15 pin connector which looks like a normal computer monitor connector. They say RGB next to them. Can you hook a PC to this connector and use the set as a computer monitor?
According to the Best Buy group (all different sales people) they said: yes, no, I don't know, why would you do that, you would have to to have DVI input, only on some, it depends on something but I'm not sure what, etc...
madmax
madmax
Vinyl, the final frontier...
Post edited by madmax on
You can hookup a pc but in most cases the best you'll get out o 15 pin is 640x480.
