Monitor 30 wall mounts?
I have ordered 2 pairs of M30's for rear and side surrounds. I know they have key slots for openings but would like to mount them. Does anyone have any experience with the Pinpoint AM-10? I know that you would have to screw into the back of the speaker. The AM-40 is the better option but they cost 60 dollars a pair and getting them shipped overseas is looking difficult. Anyone ever use the AM-10?? Your input is appreciated..
Troy_B.
Post edited by troy_b. on
If its too much trouble,you oould just use nails. I use them for my r15(almost same size as m30s) and it works just fine. If nails are long enough, you can get the speakers to hang at a slight angle. Good luckAVR: H/K AVR240
Fronts: Monitor 50s
Center: CSI3
surrounds: R15s
Sub:Velodyne DPS10
Dvd/Cd: Samsung HD upconverter (for now)
TV: 50" Sammy Plasma
game hardware: 360 and gcn.
Gamertag: kovster27 -
Thanks. I could do that and save some cash. Appreciate the input.Troy_B.
I had to ceiling mount mine and used these from home depot, so far so good. The monitor 30 is 8lbs, the ad says supports 9, but the manual says just don't mount anything over 10lbs. If you're wall mounting i'd personally just use a screw.
http://www.homedepot.com/h_d1/N-5yc1vZ1xh6/R-100671169/h_d2/ProductDisplay?langId=-1&storeId=10051&catalogId=10053 -
Thanks B Run, I think I will just screw mount them until I get back to the states in about 15 months.Troy_B.
