Desiccant packs for storing speakers and equipment
Toolfan66
Would it not make sense to use these packs when storing speakers and stereo equipment?? One could keep a pack in there speakers at all times don't see where that would hurt anything.. Depending on where one lives that could be a good idea..
Just thinking out loud.
Post edited by Toolfan66 on
No harm at all... unless you eat the contents.
TOOLFORLIFEFAN wrote: »Depending on where one lives...
Humm. Probably not a good idea in AZ. I have the opposite concern, for instance organic caps like beeswax and paper tend to dry out in the heat and low humidity. I'd let the condition of the old cardboard boxes used for long term storage in the proposed storage location guide my thinking. Colorado is pretty dry too.The world is full of answers, some are right and some are wrong. - Neil Young -
Is the storage space that much more humid than your home?
How long does a desiccant pouch last before it's saturated and therefore useless? -
Depending on location that could be a great idea!"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety."
messiah, November 23rd, 2010 -
Go to a craft store and buy flower drying crystals, 1lb box about $8. I use these for camera lenses. Keeps mold at bay. When they loose their color, you place them in the oven for a couple of hours on low heat until the color return, e.g. free of moisture. you could put them in a linen bag or a plastic container with ventilation holes.
The older vintage hardside suitcases make good storage boxes for gear. Lot better than cardboard.>
>This message has been scanned by the NSA and found to be free of harmful intent.< -
We use them at work when we pack freshly machined or washed parts. These are not your tiny sugar packet sized desi bags. Probably 3.5 or 4" square. The ones we use can be reused by baking them at a certain temp for a certain period (I do not remember either).
If you want a couple industrial strength packs Tool, let me know. I can send you a few to try.
Tim
