remote help
scottyboy76
denon av 3300 just purchased with no remote and none available new. any guidance on a reasonably priced universal or learning remote or whatever would be appreciated.
between direct sat remote and front panel buttons i have it sounding great but if an aftermarket remote would really let me get to some of the functions, i would LOVE IT. thanks. specific or general advice about aftermarket remotes would be appreciated.
humpty dumpty was pushed
Post edited by scottyboy76 on
Not sure what your budget is or what you mean by reasonable. I would recommend looking at Logitech - I own the 880 - the Harmony One will be my next purchase. Amazon.com has it at $173 less rebate. If you don't need RF then its this one:
http://www.amazon.com/Logitech-Harmony-Universal-Remote-Screen/dp/B002RL875A/ref=sr_1_1?ie=UTF8&s=electronics&qid=1282870742&sr=8-1Polk RTiA1 - front
Polk CSi A4- ctr
Polk PSW303 - sub
Polk RTM6750 satellites - surrounds
Pioneer VSX 1020
Panasonic DMP BD55 - Blu-ray
XBox 360
Panasonic Viera 42" 1080p plasma
Logitech 880 universal remote
Bell HD 6131 with ext 750 gb hd
the aftermarket remotes such as the harmony, or like one i saw on remotecentral i believe that was specifically to fill in for the discontinued manufacturers remote. are they able to actually perform most or all of the same customizing functions that the manuf. remote did.humpty dumpty was pushed
Yes the Logitech database for components is pretty deep - the buttons are customizable to do virtually everything the oem remote would have.Polk RTiA1 - front
Polk CSi A4- ctr
Polk PSW303 - sub
Pioneer VSX 1020
XBox 360
