remote help
scottyboy76
scottyboy76 Posts: 2,905
edited August 2010 in Electronics
denon av 3300 just purchased with no remote and none available new. any guidance on a reasonably priced universal or learning remote or whatever would be appreciated.
between direct sat remote and front panel buttons i have it sounding great but if an aftermarket remote would really let me get to some of the functions, i would LOVE IT. thanks. specific or general advice about aftermarket remotes would be appreciated.
humpty dumpty was pushed
Post edited by scottyboy76 on
  • Cooey
    Cooey Posts: 11
    edited August 2010
    Not sure what your budget is or what you mean by reasonable. I would recommend looking at Logitech - I own the 880 - the Harmony One will be my next purchase. Amazon.com has it at $173 less rebate. If you don't need RF then its this one:
    http://www.amazon.com/Logitech-Harmony-Universal-Remote-Screen/dp/B002RL875A/ref=sr_1_1?ie=UTF8&s=electronics&qid=1282870742&sr=8-1
    Polk RTiA1 - front
    Polk CSi A4- ctr
    Polk PSW303 - sub
    Polk RTM6750 satellites - surrounds
    Pioneer VSX 1020
    Panasonic DMP BD55 - Blu-ray
    XBox 360
    Panasonic Viera 42" 1080p plasma
    Logitech 880 universal remote
    Bell HD 6131 with ext 750 gb hd
  • scottyboy76
    edited August 2010
    the aftermarket remotes such as the harmony, or like one i saw on remotecentral i believe that was specifically to fill in for the discontinued manufacturers remote. are they able to actually perform most or all of the same customizing functions that the manuf. remote did.
  • Cooey
    Cooey Posts: 11
    edited August 2010
    Yes the Logitech database for components is pretty deep - the buttons are customizable to do virtually everything the oem remote would have.
    Polk RTiA1 - front
    Polk CSi A4- ctr
    Polk PSW303 - sub
    Pioneer VSX 1020
    XBox 360
