RTA 12 fuse
3,4,5 amps?
Hell to go through to find out something simple like that.
Post edited by Paul Millette on
    F1nut Posts: 51,870
    edited August 2010
    We make it easy. In the following link you will find the schematics for your model, which will tell you the proper fuse value.
    http://www.polkaudio.com/forums/showthread.php?t=38755
  • cristo
    cristo Posts: 231
    edited August 2010
    Look at the rta 12b orig pdf on the RTA list (3/4 amp)
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
