Acurus A200x3
Gotpolk
Gotpolk Posts: 3
edited August 2010 in Electronics
I just got some monitor 70's. I was planning on buying a Acurus A200x3 amp off CL. I have some questions on the Acurus A200x3. I've been reading that this amp runs cool. The one for sale though, has a very hot rear heat sink. The left and right heat sinks are only slightly warm.
Is there something wrong with this A200x3?
Also read that there is no speaker protection on the A200x3, will this be an issue. I would hate to fry my speakers from this amp.
Thanks in advance.
Post edited by Gotpolk on
  • DaveHo
    DaveHo Posts: 3,582
    edited August 2010
    I had an A200x3 for a number of years. Very nice amp. Heatsinks got moderately warm when pushed but never really hot. Assuming similar loads on all channels, if one is significantly hotter than the others I would suspect a biasing issue which probably indicates something else on that channel is in need of attention.
    -Dave
  • Gotpolk
    Gotpolk Posts: 3
    edited August 2010
    DaveHo wrote: »
    -Dave
    So, does this mean that I have to adjust the bias? Or does this mean that there is an issue with that channel?
    If its adjusting the bias, how would the bias have changed?
    Should I pass on the amp?
    I'm a novice when it comes to these things.:confused:
    Thanks.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited August 2010
    Wow, I've thought about checking out some used acurus amps before. Is setting bias on these amps going to cost a lot at the repair shop?
  • madmax
    madmax Posts: 12,434
    edited August 2010
    Mine gets warm but thats about it. I don't know if there is any sort of bias setting. I'd steer clear of it.
    Vinyl, the final frontier...
  • erniejade
    erniejade Posts: 6,321
    edited August 2010
    there is one on craigs list here in the IL area. I have not heard it but have heard good things about it and running hot was not one of them.
  • JAC
    JAC Posts: 23
    edited August 2010
    Acurus is starting back up again.
    Spoke with a guy from Indy Audio Labs and they will be producing ARAGON and ACURUS gear soon (some this fall)
  • Polkie2009
    edited August 2010
    I wish the best to IAL, kinda expected them to already selling the Aragon amps after talking to them about a year ago. At that time it sounded like they were starting up around Fall 2009.
  • danz1906
    danz1906 Posts: 5,144
    edited August 2010
    JAC wrote: »
    I heard that also, if these are the guys that used to work at the Old Aragon
    company.
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
