Speaker Mounts for Rti28s?
Early B.
Early B. Posts: 7,900
edited December 2003 in Speakers
I'm interested in swivel mounting my Rti28's on the wall. There are plenty of mounts out there, but most of them require drilling holes in my brand new speakers. And even if that wasn't an issue, the power port seems to get in the way of doing that. I'd prefer to somehow take advantage of the keyhole slot, if possible.
Can anyone recommend a speaker mount that doesn't require drilling holes in my speakers?
Thanks.
"God grooves with tubes."
Post edited by Early B. on
  • dorokusai
    dorokusai Posts: 25,576
    Try a clamp style mount from B-Tech. I use a BT-77 on my RTi38's.
    Crutchfield sells them.
