LGA775 motherboard
Bobsama
Hi.
I'm looking for an inexpensive LGA775 board. ATX or uATX or mITX would all work. It has to be Core 2 Duo era, so basically anything i975 or later. P, G, or X series are all fine. I'd prefer Intel chipsets but nVidia nForce boards are also options.
Don't expect $100 for the board. That simply won't fit into the budget. If you have a particularly good board (perhaps one known to do FSB400 or more with a dual-core) or one with ICH_R, I may throw a few extra dollars your way. Still, I'd like to do <$40 shipped for a low-end/non-OCing board or <$60 shipped for a board with RAID & OCs to FSB400+.
Thanks,
Bobsama
Thanks,
Bobsama
polkaudio Monitor 5 Series II
polkaudio SDA-1 (with the SL1000)
TEAC AG-H300 MK III stereo receiver
beyerdynamic DT-880 Premium (600 Ω) headphones
SENNHEISER HD-555 headphones
Little Dot MK IV tube headphone amp
Little Dot DAC_I balanced D/A converter
Post edited by Bobsama on
What CPU are you using? I have a P5LP-le (Lithium) out of a HP media center PC that I am willing to part with. It is compatible with some C2Duo cpus, I think. I think it has RAID as well.
Here's the specs:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00379616&lc=en&cc=au&dlc=en&product=1825182&lang=en#
