Reasonably priced MC step up transformer
Fongolio
I'm looking for a reasonably priced MC step up transformer. When I recently purchased my Apt-Holman pre-amp (great unit by the way) it came with a PS Audio MC step up transformer which is ok but a little noisy when cranked up and not as much gain as my Carver C-1 pre on the MC phono section. The gain part is not as important as the noise. Just a little too much hiss for my liking.
So if anyone has one they're not using and feel it sounds pretty good and won't make me need to apply for a loan I want to hear from you. Thanks.
Kelvin
Kelvin
SDA-1C (full mods)
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Nakamichi CR7 Cassette Deck
Cambridge Audio DACmagic Plus
ADC Soundshaper 3 EQ
Ben's IC's
Nitty Gritty 1.5FI RCM
Carver TFM-55
NAD 1130 Pre-amp
The Clamp
Ben's IC's
Post edited by Fongolio on
Kelvin I just sold mine. K & K audio makes good kits. That's where I got mine and it was really good. It seems they've raised the price though. Here's the link incase you want to take a look.
http://www.kandkaudio.com/phonostage.html
You could also PM Larry (analog97) he knows of other places where you can get step-up xformer kits. -
Hi Kelvin,
I have a Denon HA-500 that I am going to sell for my brother. I have one also. PM me if you are interested in his. I tested it with my DL-103r and it works well.Main system: Lyngdorf TDAI-2170 w Polk LSiM 703/ Pioneer 42" plasma w Flex Streamer, Sangaen HDT-1tuner
Bottlehead Eros
CD: DIY Shigaclone
Vinyl rips: ESI Juli@24/192->Goldwave->i7 PC server -
You can also look at http://www.diyhifisupply.com. I've heard some of their stuff, and it is actually quite good. I have plans to build a Django pre when I get that far.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
