Fun with foil caps
[Deleted User]
[Deleted User] Posts: 7,598
edited August 2010 in DIY, Mods & Tweaks
I've just confirmed a method, described in the DIYAudio forum, to determine the correct installation polarity of foil type caps. The goal is to determine the outside foil layer from the inside foil. This type of cap sounds slightly better if the outer foil is connected to the load. In order to do this you would need a Variac, oscilloscope, a small coil and a couple of clip leads. The procedure is to connect the cap's leads to a Variac and adjust the AC output to 10/15 VAC. Use two different colored clip leads so you'll know the polarity of the connections. I used a three-prong AC cord that has been cut so that the green, black and white wires are exposed plugged into the Variac so I can make individual connections to the white and black leads. Then connect one 'scope probe to one of the leads of the small coil and bring it very close to the cap. Set the 'scope to around .02V and 5mS sweep. You should now have a sine wave displayed, adjust the vertical position so you can measure the strength of the signal. Reverse the white, black wire connection at the Variac and note if the signal is stronger or weaker. Whichever connection gives the stronger signal the connection on the cap that is connected to the black wire is the outer foil side, since it couples better with the 'scope's probe.
I was testing some MIT Multi-caps and with a little practice I could easily determine the correct polarity.
Enjoy, Ken
    F1nut Posts: 51,959
    edited August 2010
    Ken, are we talking crossovers and/or power supplies, etc.?
  • Face
    Face Posts: 14,340
    edited August 2010
    Coupling caps, possibly crossovers. Here's someone else who does the same thing: http://jimmyauw.com/2010/04/24/observing-inner-and-outer-foil-of-some-popular-capacitors/
  • [Deleted User]
    edited August 2010
    Hey F1nut,
    I've not done very much work with speaker crossovers, except fixing a boatload when I worked for Polk (my wife and I still chuckle over rewinding a coil in our back yard, going from the front of the house to the alley in back). But, in general terms there seems to be a better sounding "direction" in putting a film type cap in any circuit. Some companies such as V-cap have a "green" lead and a "red" lead to tell you the "direction". Suppliers such as Michael Percy will mark one of the ends to tell you.
    I had read that the MIT RTX caps were especially sensitive to direction and that the manufacturer's label weren't always a reliable indicator of which lead was the outer one. So, I did some searching to see what I could find. Believe me, this is no reflection on MIT, just on my audiophile paranoia. There seemed to be two methods, one I described and the other involved using a sensitive multimeter and holding the cap in your hand to induce a voltage into the outer foil. I couldn't get that one to work, so I tried the second.
    Another approach would be to use clip leads to try the cap, in the circuit, with different orientations to see which sounded better.
    Ken
    F1nut Posts: 51,959
    edited August 2010
    I love this hobby. Just when I think I know it all, something else pops up. Thanks!
    You're a good man, Ken.
    SCompRacer Posts: 9,121
    edited August 2010
    Ken, I've used old open face fishing reels to rewind solenoids when the wire gauge is small enough.
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2010
    I thought this was going to be about tin foil caps to prevent the government from reading our minds. ;)
  • ShinAce
    ShinAce Posts: 1,194
    edited August 2010
    BlueFox wrote: »
    I too was going to speak of the fun I have with my tin foil hats.
    Off to the optometrist I go!
    And Ken....thanks for that tip.
