Moving from Monitors to LSi
EndersShadow
EndersShadow Posts: 17,722
edited August 2010 in Speakers
This move is a long term goal and not likely to take place until next year, however I want to start my research now so if something good comes along I can jump on it.
Currently I have a set of Monitor 60's for my fronts, a pair of Monitor 40's for surrounds and a CS2 center. The front three are being driven by a Carver 705x amp and the surrounds by my Integra DTR 5.9 receiver.
With the launch of the New LSi series this week there is going to be a drop of some sort in price for the older LSi lineup, both online and for used. I have always heard these are the cream of the crop Polk speakers and as such am interested in possibly picking up some for both 2 channel listening and also Home Theater use.
I am wondering the following:
1) Will LSi fronts pair well w/ Monitor 40 surrounds or should I replace those? My receiver will not do 4 ohms well if at all so keeping these would be preferable as replacing them would require the purchase of another amplifier.
2) What fronts should I go with: LSi 7's, 9's, 15's? The 25's are out of the budget and have heard they require much more tweaking to get them to integrate right with subs. The 15's have a 8" driver which should sound nice, however I dont know how easy they are to integrate either from what reading I have done.
3) Will the Carver amp be able to drive the front three? I found a review (here) that lists some decent 4 ohm spec's w/ 2 channels driven (283 wpc), but nothing listed beyond that. I am willing to drive just the front three from the amp (since one of the channels is bad anyway) and let the AVR do the rest (or if needed another 2 channel amp).
4) Is the LSi line one I should look into or should I just go with the RTi series?
I have attached a picture of the layout of the apartment so you can see what kind of space I have to work with. I know the 15's require some decent room on either side and out from the wall (but I forget how much).
Post edited by EndersShadow on
  • BlueFox
    BlueFox Posts: 15,250
    edited August 2010
    With the launch of the New LSi series this week....
    Is this true?
    edited August 2010
    edited August 2010
    anyone?
  • mystik610
    mystik610 Posts: 699
    edited August 2010
    Timbre matching surrounds to your mains isn't a necessity. I'm using FXi3's with my LSi9's and don't have any issues. At times when the surrounds are really active, the brightness of the FXi's tweeter overwhelms my LSi9's, but it isn't anything that's making me want to run out and replace them.
    Depends on how badly you want the extra bass extension from the 15's. If you're using a sub, the LSi9s should suffice. The LSi9's have can put out some suprisingly good bass...not enough to replace a high-end sub for home theater impact, but good enough for just about any genre of music.
    Never used a Carver amps so I can't speak from experience...but based purely on the amps specs, it shouldn't have any trouble driving the LSi's
    Audition both and see what you like.
    I've gone from the R50's, to the TSi300's, to the RTi8's, and now to the LSi9's.
    I prefer the LSi's over the RTi's for both music and movies (now that I've mated the LSi's with the right gear).
    I posted a comparison of the RTi's vs the LSi's here:
    http://www.polkaudio.com/forums/showpost.php?p=1384532&postcount=5
    My System Showcase!
    Media Room
    Paradigm Studio 60 - Paradigm CC-690 - Paradigm ADP-390 - Epik Empire - Anthem MRX300 - Emotiva XPA-5
    Living-room
    Paradigm MilleniaOne - Rythmik F12GSE - Onkyo TX-SR805 - Adcom 5400
    Headphones
    Sennheiser Momentum Over-Ear - Shure SE215 - Fiio E18 Kunlun
    edited August 2010
    mystik610 wrote: »
    Good, I thought that would make life easier as I already have the 40's, they are wall mounted, easy to drive and work perfectly as it stands
    mystik610 wrote: »
    Yeah right now I just have a PSW125, but looking to get a SVS PC-12NSD (and then another), so the bass will be well taken care of later. My only thought was that decent stands are not cheap and the 15's are floorstanders.
    How do the 7's compare w/ the 9's? Is it close or one of those not even in the same ballpark kinda deals?
    mystik610 wrote: »
    Yeah it looks like the Carver would be ok, or as stated I could get a one channel amp for the center to seperate it if needed. As long as I only have to drive the front 3 from the amp I think I should be fine
    mystik610 wrote: »
    Yeah I am going to check that out, and like I said this is a long term goal. Its just really hard to find someone here local w/ the LSi's. If I want to listen to the 9's Fry's at least has those, but I have yet to find the 15's anywhere.
    I might have to head out to Fry's sometime this week just to listen and actually deal w/ their stupid sales folks since they redid their system to make it harder to demo w/o a salesman's help :(. They also have the RTI A9's too.
