Multi-Channel Amp, AVR
mole'
im looking for a 5 good Channel (200wpc+) amp. something under $1000
something to drive my new SDA SRS 2.3TL's
also looking for an AVR for the bedroom. would like it to have atleast 2 HDMI inputs (DTV/PS3) and 1 output. Pre-outs would be nice too. $400 max
thanks for looking
thanks for looking
mole'
Post edited by mole' on
Have you tried "Emotiva" ? Go to their website and look at their amps.
ayates2611 wrote: »Have you tried "Emotiva" ? Go to their website and look at their amps.
i have looked at the XPA-5
have read that it makes your speakers sound "BRITE"mole' -
The ONLY way to fly based upon your request would be with a Sunfire TGR-3... it is a seven channel that will let you use the unused channels for bi-amping.
http://www.sunfire.com/pdf/TGR3_manual.pdf
And the ONLY way to grab one would be to go used... They can be had for a grand or less.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
mole', If I were you I would wait until you have all your new speakers in place, listen to them first through the SC-07 amps, then through the amps you currently have (which are pretty good amps IMO).
You may find that you may not need to spend more on a different amp.
i know thats a good idea, but i dont have the space for 2 amps right now.
and still trying to find a good rack to hold me gearmole' -
nooshinjohn wrote: »The ONLY way to fly based upon your request would be with a Sunfire TGR-3... it is a seven channel that will let you use the unused channels for bi-amping.
OHHHHHH!!!!!!
gonna look it up right now.
SNAPS!!! $1500mole' -
Combine the money for both rooms and let the Sunfire run the whole show.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »Combine the money for both rooms and let the Sunfire run the whole show.
would be nice if i could do that. the front room setup and bedroom are like 150ft apart. not gonna happen.Ok if you have space constraints and must go to a single amp, how about this one:
http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1287002092&/Outlaw-770
Looks like a beast of an amp. 90 lbs and TWO massive toroidal transformers.
thats a big amp. specs are close to that sunfire.mole' -
Wait a minute. I just googled the Sunfire TGR-3 and it is a receiver, not an amp as the OP is looking for. :rolleyes:
LMAO... saw AVR in the post... my bad.:eek::cool:
Try this one...
http://cgi.ebay.com/Sunfire-Cinema-Grand-5-Channel-Power-Amplifier-400-WPC-/290461971903?pt=Vintage_Electronics_R2
I will help you get Bob Carver's signature on it if you get one. I think they look sexier that way.:DThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
nooshinjohn wrote: »LMAO... saw AVR in the post... my bad.:eek::cool:
Try this one...
i saw 5 channel /400wpc and was like that is awesome. i want!!! but thats at 4ohms.
looks like a nice amp. im gonna keep an eye on this one. thanksmole' -
The Sunfire would be a good choice all right. Also if you are interested in a Pioneer VSX 84TXSi for your bedroom, let me know. I just replaced it with Sunfire equipment, and would let it go to a fellow Polkie for $400. PM me if interested.Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
mole', If I were you I would wait until you have all your new speakers in place, listen to them first through the SC-07 amps, then through the amps you currently have. You already have some very good amps IMO that should rock your setup.
Just trying to save you some money brother.
Then again you seem to have an unlimited budget for your A/V equipment (I'm kind of jealous man LOL).
I would not run the 2.3tl's with the SC-07...
Just my humble opinon.. Get the sunfire and if your not going to get it I'm going to bid on it.. no sense in us having a bidding war..;) -
^^I suspect that this one will go for less than $600.00The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
TOOLFORLIFEFAN wrote: »I would not run the 2.3tl's with the SC-07...
go for it man.nooshinjohn wrote: »^^I suspect that this one will go for less than $600.00
its at $600 right now.mole' -
Here is a nice one on CL if anyone lives on the east coast.
http://newhaven.craigslist.org/ele/1899664275.htmlHT System
Parasound Halo A51 Amp, Marantz AV 8003 Pre, Arcam FMJ CD36 cd player, Marantz 7007 BD/SACD player,Acoustic Zen Matrix IC's, Analysis Plus Crystal Copper Oval IC's, Acoustic Zen Satori speaker cables, B&W 703's Fronts, Center Martin Logan Motif hybrid, Surrounds DefTech BPX, 2 X DefTech Supercube Reference Subs, DSpeaker Antimode 8033 EQ. -
300wpc would have been nicemole' -
Oops, My mistake! Only a 2 channel:oHT System
it has 2 channel/inputs on each side
i wounder if you could run your front and rears off of that? and then get a mono for the centermole' -
mole'
it sold for $680 plus $61.20 for shipping
That's funny, I tried putting a last second $700 bid on that same amp, but my connection was too slow. $680 seems like a good deal.
Oh well, maybe next time.HT: RTi8s, CSi3, RTi4s, HSU ULS-15, Pioneer Elite VSX-23TXH, Sunfire Cinema Seven.
2CH: CJ MF2300, Parasound P3, PS Audio DLIII, Wadia 170i, Music Hall Maverick, Sierra-1s, Sunfire HRS8 -
thanks for looking
Don't know if your still looking or if this is even what you want. But I have an almost new Onkyo TX-NR807. A little higher than your $400 max but $450 plus shipping and you got it. 4 hdmi in, 135wpc x7 and pre outs. Everything included and in original box.
GeorgeFronts: Polk RTi A7's
Center: Polk CSi A6
Surrounds: Polk TSi500's
Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
Amplifier: Emotiva XPA-5
Processor/AVR: Emotiva UMC-1
DAC: Emotiva XDA-1
CD player:Emotiva ERC-1
Blu-Ray: Oppo BDP-93
Turntable: Kenwood KD-500
Tonearm: Polk-Mayware Formula 4
Cartridge: Shure M97-XE
Television: Sony KDL-55EX500 -
ill be picking up a XPA-5 from a local tomorrow and as of now im planning on getting the Pioneer VSX 84TXSi from helipilotdoug. if the deal for the Pioneer is a no go, ill get the Onkyo TX-NR807 from geebolt. thanks everyone for the info and help.mole'
so i was gonna meet up with the guy for the XPA-5 today at noon. he emailed me at 3am saying its no longer FS. WHAT GIVES?????
man im so mad about this. anywho, im looking for a nice 5ch 200wpc+ amp againmole' -
I have this little known AVR and it sounds awesome.
http://cgi.ebay.com/Adcom-GFR-700-7-1-channel-Receiver-FACTORY-SEALED-BOX-/230404700722?pt=Receivers_Tuners
runs my LSi setup w/ no problem. -
Just a word of caution, since I saw someone mention an Outlaw 770. I have one also, & they are not a common ground design. I beleive this is true of many of the Outlaw multi-ch amps.
-Dave -
Find a Sunfire like what nooshin was recommending, you won't be dissapointed. Emotiva is alright, but if you have the scratch for a Theater Grand Sunfire, it's a no brainer IMO.Home TheaterRTiA5 - CSiA6 - FXiA6 - PSW650 - Pioneer Elite SC-55 - Carver AV-505 - Sony 46" 120Hz - Monster HP 2400 - Xbox 360 - Playstation 32 ChannelPolk RTA 15TL - Harman Kardon HK3485 - HK DVD48 - Signal Cable IC's and speaker cables
It's not 200 watts but close. And cheap too. If you don't bite, I'm going to see if the old lady will let me take it. http://www.audiogon.com/cgi-bin/cls.pl?ampsmult&1287341054&/Adcom-GFA7000Display: Sony 42" LCD
Sources: Harman Kardon DVD-27,
Panasonic DMP-BDT110 blu ray player
AVR: Sony STR-DA2400ES
Amps: Sonance Sonamp 260(fronts),
Kenwood KM-894(surrounds)
Fronts: NHT 2.5
Center: NHT VS-1.2A
Surrounds: NHT Super One
Subwoofer: SVS PB10-ISD -
That sucks mole'. I hate when people aren't true to their word. :mad:
The same thing happened to me a couple of months ago when I found something on Craigslist I wanted. I emailed the guy from work, he gave me his address and said he would hold it for me until I got there. Just as I got off work and was heading to his house he called me and said he sold it to someone else.
Then again I have also had things for sale myself, had someone say they were going to be here to pick it up at a certain time, and never show up.
I think some people are afraid of this happening so while they may promise it to you, if someone else shows up with cash in hand they just let them have it.
Well I'm sure you'll find yourself another amp soon enough and maybe even get a better deal while your at it. Good luck.
man i was so mad. i asked the guy if he wanted me to send him some $$$ to hold it. he said no, ITS YOURS!
i worked around the times he could meet up. OH WELL!!! live and learn just like them FAKE EBAY MIT's lolmole', you need to clear your inbox. I want to send you a link to an amp.:)
CLEARED!!!!mole' -
thanks for all the Links guys. im gonna check them out tonightmole'
no longer in need of an AVR. got the Pioneer VSX 84TXSi from helipilotdoug. thanks
thanks geebolt for the offer thomole' -
Sir:
I have a 5 Channel Fosgate Audionics FAA 1000.5 Amplifier in PERFECT condition. Original Packaging, etc. I HAD it running off of my Yamaha RXV 863, which I still have too. I have all of the wiring to daisy chain the receiver of your choice to this amp. Wires are by Signal Hi-Fi. The speakers I ran with this were all Polk LSI 9s, LSI C, LSI FX. I was sickened to have to sell all of this gear. The economy sucks.
If you are interested in any of this. Oh, I also have a Definitive Tech Supercube I. Mint condition, as well. AND speaker wires from Signal Hi-Fi for front end LSI stage. All wires are bi-wire specific for the Polk Lsi Front Stage.
Please call me if you are interested. My name is Jonathan and my number is 602-799-8738.
Thanks For Your Consideration
