A Good Test DVD
Oskarom
Hi, I need a realy good dvd disc to show off my HT
what should i use?
what should i use?
Post edited by Oskarom on
Lord Of The Rings: The Two Towers, Extended or not. What are you runnin anyway?Panasonic VIERA 46" 1080p plasma
Onkyo TX-SR805
Klipsch RF-7(bi-amped)
Klipsch RF-25
Xbox 360 with HD DVD
Playstation 3
Cobalt Cable -
Lors of the Rings, U571 depends on the type of movie you like or your guests like.
DanRecever AVR 8000
Amp PA 4000
CDR 26
Mains RTI 150 Bi wired
Center CSI 40 Bi wired
Surround FXI 30
Rear RTI 4
Sub PSW 140 -
T3. My new benchmark.
Welcome to the forum.
If you're really from Iceland Iceland, I think you're the furthest away from the motherland......
Let us all know what your system consists of. We all like to know..........comment comment comment comment. bitchy. -
Agreed T3 is what should be played right now.
My standard for many many years with laser discs and DVD's has always been "Apocalypse Now". There are many excellent scenes but this is my favorite for impact. The Scene where the helicopters attack the beach and then they try to surf the beach. "Charley Don't Surf". Veterans from the war after seeing this scene will have bad nightmares that night. The loud womp/womp/womp of the helicopters is subliminal. The scene still gives me goose bumps seeing what war/death can be like.
Nobody wins in war except the large corporations that make weapons.
War Sucks. -
SUPER SPEEDWAY: THE MACH II-SE DTSPanasonic TH-50PX80U Plasma HDTV
Polk Audio RT800i (fronts)
Polk Audio CS400i (center)
Polk Audio F/X1000 (side surrounds)
Polk Audio RTi6 (back surrrounds)
Velodyne CHT-15 (subwoofer)
Yamaha RX-V1400 (Pre/Pro)
NAD C272 (2-ch Amp)
Adcom GFA-7605 (5-ch Amp)
Toshiba SD-3109 (DVD/CD player)
Malata DVP-580 (Multi-region DVD player) -
Saving Private Ryan in DTS. Still a TOP contender.Mains: polkaudio RTi70's (bi-wired)
Center: polkaudio CSi40 (bi-wired)
Surrounds: polkaudio FXi30's
Rear Center: polkaudio CSi30
Sub: SVS 20-39 PC+
Receiver: ONKYO TX-SR600
Display: JVC HD-56G786
DVD Player: SONY DVP-CX985V
DVD Player: OPPO DV-981HD 1080p High Definition Up-Converting Universal DVD Player with HDMI
Remote: Logitech Harmony H688 -
T3 here as well. That crane sequence is awesome.
Peace Out~:DIf...
Ron loves a film = don't even rent. -
First of all I want to thank you all for great replys
You can see my setup at the system showcase (I'll post some pictures later when I have digital camera)
And yes I'm really from Iceland
and i live in the capital city Reykjavik (it's almost the same sice as the small towns in the US) -
I like the sampler disks from dts. #4 is really good. Check ebay to see if you can get your hands on one.
Don't forget Star Wars. put it up around 65 db and enjoy.
65db? how about 80 to 90db seems more like it.. or more. 65db for me in my room. would be like the volume of someone talking.. loud. is that 65db you are thinking of with a SPL meter? when you set your speakers up using a SPL meter.. they say to set the tone to 75db, usually.
so i'm thinking 65 db is pretty low... unless you don't like high volumes.. then 65db might be ok. for me it would be way to low.PolkFest 2012, who's going>?
To have "theater" like sound they recomend 85 db on the meter. However this is probably to loud for most in a much smaller room. so they say to set it at 75db like danger said. The lower the setting you can start to lose some of the detail and effect the director wants in the movie.
DanRecever AVR 8000
Amp PA 4000
CDR 26
Surround FXI 30
Rear RTI 4
Sub PSW 140 -
Just for sh!ts and giggles, I have to check this out. I'll let ya know.:rolleyes:
The opening scene of Ice Age is kinda cool for testing a ht system. And yeah I don't think 65 dB will give you much of a feel for the sweetness of your system but I guess it all depends on your room size and whats in it.
I checked out Star Wars, Attack of the Clones.
First the system was recal'd at the recomended 85 db level using a RS analog SPL meter, set at 70 db, slow weight.
I thought it was pretty good at an avg. 65 db. Parts of the soundtrack peaked out and pegged the meter, but overall it was loud enough. I know this will differ w/ diff. set ups and different strokes for different folks.
But it worked for me. It was loud enough to enjoy with out killing you.:)
Now when I crank up the tunes, it's a whole nuther ball game!!!;) -
fair enough... equipment and room size and speaker placement and acoustics all play into how your ears here and decipher the sound coming out of your speakers. if 65db is plenty loud.. it's great.. 65db it is.
glad to see you used and SPL meter. It does make all the difference in the world. I'm curious.. where were you in the room when you took those readings?PolkFest 2012, who's going>?
i just popped in Star Wars ATOTC at 65db... it was pretty low on my system. to low for a movie of that stature... maybe for a chick flick it would be ok..
you guys should check out the new A Perfect Circle album "Thirteenth Step"
Track 3 and go straight to 1:45 and listen -
Great album.
Been thier done that.
Pet is the best title on the cd ...IMO
Not a good Test DVD though;) -
I'm not even sure where to start with this one. Could someone PLEASE help amulford come up to speed on system calibration with an SPL meter?"What we do in life echoes in eternity"
SVS -
I was set up as follows: sitting in my usual pos w/ the meter set up on a tripod right behind my head, pointed upwards slightly. I knelt to the side of the meter to note the levels.
Dr. Spec.: I am sorry, I calibrated the system with the meter set in the 90 db range, c weighted, slow response. I had the meter set to 70 to do the listening test, c weighted, fast response. -
Hi amulford:
How did you calibrate your system? Test tones, calibration DVD, etc?
Are you just channel balanced, or are you also calibrated to Reference Level?
If you are calibrated to Reference Level, what is your Master Volume setting for Reference Level? And what is your normal preferred Master Volume setting for DVD playback?
No need to apologize......just trying to get a feel for how loud you are playing back the system."What we do in life echoes in eternity"
SVS -
Dr. Spec,
You'll have to excuse me for I am rather new to this genre. Please let me know if I am doing something wrong or lacking in some respect.
I used the test tones (white noise) generated by the receiver, a Sunfire Ultimate. I bought a cal. dvd from RS once, but did not have much luck with it. Have not gotten another as of yet (nay suggestions?
I believe the speakers are balanced, but I try to do this at 87 db (which show up as -2 on the 90 db scale).
I cannot tell what the actual volume setting is during cal, for the display is showing the speaker.
Normally I set the volume on the receiver to around -35 to -30 (with 0 being the highest) during movie playback.
I have noticed the dvd output seems to be considerably lower than radio tuner, the reason for that I do not know.
Am I going about it right?
anthony
