HELP!! Ohm rating for monitor 7's!!!
crackerbuzz
crackerbuzz Posts: 10
edited August 2010 in Speakers
Hi there!
Does anyone know which model these are as I have just purchased?
They have the "polk audio" badge on the front of the black cloth covers at the bottom.
I need to know whether this is the early model running 4 or 6 ohms or whether this is an 8 ohm speaker.
Please help as my amplifier needs to know!
Post edited by crackerbuzz on
  • crackerbuzz
    edited August 2010
  • zippty2001
    zippty2001 Posts: 232
    edited August 2010
    i might be wrong but the 6.5 don't look like they should they don't look like Polk's take one out and take a picture of the back please
  • Log1x
    Log1x Posts: 71
    edited August 2010
    http://www.polkaudio.com/homeaudio/specs/recent/monitor7/
    I can't tell 100% from the pictures, but I agree with zippty..the 6.5" drivers look like they have been replaced.
    But to answer your question, the specs page reports these speakers run at 8ohms.
    Tad larger of an image showing how the driver should look. (Google)
    Music [2.2]
    Speakers: polkaudio RTi12
    Future Speakers: DIY Fusion-15 Sentinel's
    Subwoofer: DIY Dual LAB15's
    Subwoofer Amp: Behringer iNUKE NU6000DSP
    Preamp: Emotiva XSP-1
    Amp: Emotiva XPA-2
    CD Player: Emotiva EMC-3
    DAC: Emotiva XDA-2 Gen2
    Turntable: Denon DP300F w/ Ortofon 2M Red
    Tuner: Rotel RT-1080
    Power: Monster HTS 5100 MKII
    Amp Power: CyberPower CPS-1220RMS
    Interconnects: Emotiva USS [4], XLR [6], X RCA [4], MUSB [1], X IEC [4]
  • crackerbuzz
    edited August 2010
    I will do...Will be in a couple of days...
    Cheers
  • lightman1
    lightman1 Posts: 10,796
    edited August 2010
    Peerless tweeters. Good.
    Knock off mids. Bad
    Passive radiators look correct.
    If there is no damage to the wood where the mids mount, you may be able to salvage a damn fine set of bookies.
    And...whatever you do do, crackbuzz, do not tell anybody here I talked anything about audio.:cool:
    F1nut Posts: 51,778
    edited August 2010
    Don't worry, you still haven't.
  • lightman1
    edited August 2010
    Thanks Jesse. I'll get better from here on out....on the forum.;)
  • lightman1
    edited August 2010
  • kcoc321
    kcoc321 Posts: 1,788
    edited August 2010
    Log1x wrote: »
    http://www.polkaudio.com/homeaudio/specs/recent/monitor7/ But to answer your question, the specs page reports these speakers run at 8ohms.
    The spec page you quoted above is for the Mon 7 Series II, which is not the speakers he has. He has the Earlier version Mon 7b, with the Peerless tweeters.
    His "Correct drivers" are actually different as well. The first ones had a Masonite ring, like is shown on his passive radiators.
    I believe the Mon 7B's are 6 ohm (But it is lateand I am too tired to look it up), but that being said, I have read that the switch just limits the receiver. If you don't krank it, then it is probally okay set at 8 ohm, but that is just what I have read...
    Thanks for trying to help, though :D
  • Log1x
    Log1x Posts: 71
    edited August 2010
    kcoc321 wrote: »
    Whoopsie. :)
    My apologies. Thanks for clearing that up.
    Music [2.2]
    Amp: Emotiva XPA-2
  • skrol
    skrol Posts: 3,451
    edited August 2010
    The Model (Monitor) 7 were listed as 8 ohms
    Monitor 7A were ?
    Monitor 7B were ?
    Monitor 7C were early 4 Ohms, later 6 Ohms
    Monitor 7 Series 2 were 8 Ohms
    With the wrong mid-woofer, who knows.
    Stan
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • crackerbuzz
    edited August 2010
    I'll rip the mids out and check the make... They look like VIFA?
    If I chuck a meter across the terminals it should show mw the impedance?
    Also where could I get some genuine mids for these?
  • kcoc321
    edited August 2010
    The best place for the vintage MW's is on the Forum. You MIGHT find a pair on EBay, but who knows about them. Try posting a "WTB" thread. They come up from time to time. Good luck
  • crackerbuzz
    edited August 2010
    Ok, my system is running!
  • crackerbuzz
    edited August 2010
    I will replace the polk mids when I find a 6.5 incher that will suit, although they do sound quite nice with everything running together!
  • crackerbuzz
    edited August 2010
  • HB27
    HB27 Posts: 1,518
    edited August 2010
    You might want to show some up close detailed pics of your crossovers so you can get the correct mid woofers for those.
  • crackerbuzz
    edited August 2010
    I have located some 6.5 inchers...
    POLK AUDIO MW7005 drivers.
    They are the correct ohm rating.
    Do you think I can use these as a replacement for the ones that have been thrown in at the moment?
    Any help would be appreciated.
    Cheers
  • skrol
    skrol Posts: 3,451
    edited August 2010
    There is more to it than ohms. The original would have been an MW65xx series and most likely MW6502.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • crackerbuzz
    edited August 2010
    Thanks, WHere can I get some?
