dvd player???
warviper
warviper Posts: 585
edited December 2003 in Electronics
I need some recomendations for a dvd player that gives high quality audio and video that plays mp3 vcd best bang for the buck in your opinion is fine. Thanx for the reply. I own a hdtv and it has a dvi and component out. the reciver is a Yamaha rx-v2300.
Wish I was a polkologist then I could call my self Dr.warviper.
Post edited by warviper on
  • jdavy
    jdavy Posts: 380
    Look into panasonic. I got a combo player for my son, and it playes almost every disk I can put in it. Quality is very good for the price point.
    Good luck
  • warviper
    warviper Posts: 585
    thanx for pointing out the panasonics but ny question was more likeis there a difference between a 200.00 and a 500.00 and whats the deal with the 1900.00 ones, i know they are superior but how and are they worth the dough dollar for dollar. Or are they like the cable issue upgrade if you can afford it. I know there is a middle ground with this forums help I hope to find it. thanx:D
  • Tour2ma
    Tour2ma Posts: 10,177
    Denon DVD-2900 - It's the one on my list... Dealtime prices range from $750 to $999.
    http://www.usa.denon.com/catalog/products.asp?l=1&c=4
    More later,
    Tour...
    Vox Copuli
  • kureboy99
    kureboy99 Posts: 53
    On the $$$ panny's, the video and audio might be slightly better but not to warrant the super increase in price. Also, unless you have super video equipment...you will really not notice the difference anyway. I had the Panasonic RP-91N which was an awesome unit and for $299 closeout now (crutchfield.com), it's a sure winner. It's gotten great reviews by users as well as videophile reviewers online and in mags. Good luck :)
    ...See the Music, Feel the Music, Be the Music...
  • brettw22
    brettw22 Posts: 7,623
    Looking at the upclose and personal photo, it occurs that the thing I don't like about Denon is those dot matrix displays. I think that everything has LCD type that I have now, which IMO looks much more sleek.........
