Greetings to everyone!
bajaf
Greetings. I'm from spain, from Barcelona. Throught my local dealer, I'm going to buy a Polk home cinema system, R15 for surround, Csi30 for center and for front channels well, I dont know. First of all, which receiver? I doubt between a Marantz Sr4300 or a Denon 1603. Use 95% cinema. Which better?
And which front channels floor-standing speakes?
A rti70 which this type of receiver (low gama) is too much? Better R50? Subwoofer is needed using a floor standing speaker?
Another advice?
A last doubt. My local dealer show to me a new center channel model, exactyly Csi25. But not appear in the products of polk audio. What happens?
Sorry for my english language. I know is not very good.
Thanks for everything and i see you all in this forum.
Greetings.
Another advice?
Greetings.
Post edited by bajaf on
Welcome to the forum! The Rti70's are much better than the R50's. Since you watch 95% cinema, a subwoofer is needed for the full range of sounds that are found in movies. I have not used either one of those receivers.
Regards,
PolkThug -
bajaf,
The best way to test what you think you might like is to match the amps and speakers in the store. With the money you are going to pay, they should be happy to help. BTW you use 220 in spain and I do not know how that would affect any amp recomendations we might have.
James
