Best In-Wall/Ceiling speaker cables?
dpowell
Doing a new home theater install and would like recommendations for good 12 gauge speaker cable to use for the install. Using SRT mains and Center (have an MIT cable for the center) and Polk TC265i in-walls for all 4 surround speakers.
I want something that will sound good but not break the bank. Plus, I want the joy of watching a bunch of people argue that I should just put in Cat6 or lamp cord instead of real speaker cable.
Rear speaker runs will be approx. 35'
SRT speaker runs will be approx. 15'
Another piece of info I'd like is what Subwoofer RCA cable to use. I'll need about a 25' to 30' run out to the SVS.
Also, if anyone wants to chime in on a good place to buy a 35' HDMI cable, S-Video cable and VGA cable I would appreciate the info.
Thanks!
Thanks!
Post edited by dpowell on
Check out monoprice.com(3) PS3's, Xbox 360, (2) Wii's and Nintendo NES
(2) Panny DMPBDT110 3D Standalone Players
Panny 60" 3D Plasma TC-60ST30
Panny 50" Plasma TC-P50G10
Panny 50" 3D TV TC-P50GT25
Denon AVR-891
Harmoney One Remote
Polk Monitor 70's,Polk CS2, Polk Monitor 40's -
Thanks, I'll check out both of those suggestions.____________________________________________________________
polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, McIntosh C2300, Marantz AV7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Sim Audio Moon 380D DAC, EPSON Pro Cinema 6050 -
A 250' spool of 12g CL2 rated wire from Monoprice is $60, and it's the best stuff you can get for the money.
I would check with parts-express. I would consider getting a four-wire run and twist two of them together at the terminations, however, this is not necessary. you can use 14g for those short HT runs, HT sound is not exactly delicately layered and textured with acoustic space, air, oh yea, and musicality. Having CL rated wire is though what needs to be used.
RT1 -
Belden 5000: http://www.bluejeanscable.com/store/speaker/index.htm
Goertz Flatwire: http://www.goertzaudio.com/contents/en-us/d20_Flatwire.html
I have some flatwire currently not in use that will be long enough for your SRT's, PM me if you're interested."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche -
A huge +1000000 for the Canare 4s11.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
As great as the 4S11 sounds, it's not rated for in wall."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
Thanks for the suggestions! All of the cable will be technically in-wall however the wires for the mains will be accessible (i.e. not drywalled' over) from behind the equipment and screen so I don't know if 'in-wall' rated cable is necessary for those runs.____________________________________________________________
