multiple subs
greene1968
ive been reading on running 2 subs..and see it says..only run identical subs,when running more than 1. Any truth to this?
Post edited by greene1968 on
greene1968 wrote: »ive been reading on running 2 subs..and see it says..only run identical subs,when running more than 1. Any truth to this?
I run 4 subs 2 svs 2 paradigm no problems.:) -
i see alot of people run different subs..hence the reason im asking. Ive read not to do it..but cant figure out why.
greene1968 wrote: »i see alot of people run different subs..hence the reason im asking. Ive read not to do it..but cant figure out why.
Mostly because it is sometimes a **** to get them all to play nice together...."....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
my sub placement is less than stellar, only place to put it was in the middle of the back wall, behind the couch. (svs 20-39), i just put my bedroom sub(velodyne dps10) on a side wall and the bass response seems to be a little better with both subs playing..guess i'll play with it and see:D
I have an Infinity PS210 and Velodyne DPS-12 on either side of our loveseat towards the back of the living room, and it sounds incredible (once balanced properly.)polk monitor 70's
center - polk monitor cs2
surround - polk monitor 60's
surround back - jbl e10
sub - velodyne dps 12
sub - polk psw110
avr/pre-amp - onkyo tx-nr809
amp - adcom gfa-5500
amp - carver av405
display - sharp lc70le847u
tv - silicon dust hd homern
blu-ray - oppo bdp-103
hd dvd- toshiba hd xa2
control - logitech harmony one
turntable - technics sl1500 mkII -
i ended up putting my velodyne back in the bedroom. I dont think it was helping my setup much, if any. Probably due to where they were placed
greene1968 wrote: »i ended up putting my velodyne back in the bedroom. I dont think it was helping my setup much, if any. Probably due to where they were placed
Time and patience in experimentation will get you there. -
so true..but my wife and home theater dont go together. Im looking to achieve good sound, she would rather have a bose setup..lol
