SDA-SRS vs SDA 1.2 how to tell
On3s&Z3r0s
Does anyone know if there's a way to tell the difference between the first generation SDA-SRS and the 1.2? From looking at the driver table it seems like the only difference is the dimensional MW's and the crossover. There's a pair for sale on CL in my area (actually mentioned on another thread here), and even though it means risking divorce they might be too good a deal to pass up.
Anyway, is there anyway to tell the difference without opening them up, and does it even matter, assuming everything is in good working order? Is the 1.2 with the dimensional MW6511's head and shoulders above the SRS with all MW6503's?
Thanks!
Thanks!
If they have a blade/blade connector, it's definitely non 1.2 (SDA SRS), 1.2 would have pin/blade for the interconnect. Most other differences would be internal.Main System: Polk SDA SRS 1.2 Speakers, Sunfire Signature 600~two Amp, Carver C-16 Preamp, Carver TX-11b Tuner, Marantz 6350Q TT, Philips CDR-775 Recorder, Teac V-707RX Cassette Deck, Signal Cable Double Run Speaker Cable
Upstairs Den: Marantz 2325 Receiver, Marantz 5220 Cassette Deck, Marantz HD-880 Speakers, Marantz 6370Q TT
Exercise (Kabuki speaker) Room: Kenwood KR-9600 Receiver, Pioneer CS-99a Speakers, Sansui SP-X9000 Speakers (not pretty, but LOUD!
Awesome, that would be easy to check. Thanks!
