Tube Amp on the Highs SS on the Lows??
Toolfan66
Toolfan66 Posts: 18,061
edited August 2010 in 2 Channel Audio
Has anybody tried this?? Bi-Amp with a Tube Amp and SS Amp??
Just Curious..
Post edited by Toolfan66 on
  • Face
    Face Posts: 14,340
    edited August 2010
    Yes, it can be difficult to pull off though. I used a SS amp on the bottom that had attenuators, so I was able to level match between the top and bottom amps.
    treitz3 Posts: 19,992
    edited August 2010
    Ahhhh, the million dollar question.
    Good luck and happy listening but the rabbit hole will not let you in....[unless].....even then......
  • Conradicles
    Conradicles Posts: 6,343
    edited August 2010
    You brought Tom out of the woodworks...
  • organ
    organ Posts: 4,969
    edited August 2010
    What speakers are you using? This type of bi-amping works better on 3-way speakers than 2 ime. In a 3-way, you can use the tube amp to power the mids and highs. If you're able to match the gain on both amps, try it.
  • zingo
    zingo Posts: 11,258
    edited August 2010
    organ wrote: »
    Bingo
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited August 2010
    gain is certainly a consideration a big one, there are others, speed? tonal character? signal handling? balanced circuit? unbalanced circuit, I guess the questions are near endless, if the idea just burns and you gotta have it, sure go for it, hear it, we did it here years ago, lets just say those fellows I know did not continue on with it,myself included.
    RT1
    edited August 2010
    Add another one to the list, Ted. Basically it sucks.
    You may gain some attributes but you lose so much more of what the goal is. Which makes it, well.....not worth it in the long run. Eh, if you want to experiment? Have fun as I'm sure some of us did. Ya' gotta learn somehow.
    edited August 2010
    It just crossed my mind if anybody has tried it. Sounds like one should stay away from it..
    nooshinjohn Posts: 25,925
    edited August 2010
    I am very happy with SS power and Tubes for my pre, but that may change IF my new project gets off the ground.:cool:
    edited August 2010
    Dude, that's a completely different scenario.
    edited August 2010
    treitz3 wrote: »
    Yep!! I'm running a tube pre, and a tube phono pre..
  • Face
    Face Posts: 14,340
    edited August 2010
    There was another time a friend and I gave it a try. We used an Ayon Crossfire as an integrated amp on the highs and mids of his Acoustic Zen Crescendos, then used the pre-out on the unit to a W4S amp for the lows. We had to use a stepped attenuator between the Ayon and W4S to lower the gain a bit, but it sounded wonderful.
