Two system using one sub?
Bante
Bante Posts: 2
Hi everybody!
I got a 5.1 hometheater and a two nearfield monitors I use in my daily work with my computer, that I would like to hook up to my dsw500 subwoofer. The sub sure has two seperate inputs I can use but is it safe to hook up the Lfe input from my receiver and the two RCA inputs from my monitors at the same time?
Any help appriciated.
/Martin
Post edited by Bante on
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited July 2010
    Go speaker (high) level for the monitors, LFE for the theater. I don't *think* one will override the other, but until I verify with Polk CS, only have one 'on' at a time.
    It's MacGuyver'd, but I think it will work - I did the same thing essentially for one zone in my whole house audio rig some time back.
    Welcome to the board, and thanks for choosing Polk!
    Cheers,
    Russ
  • Bante
    Bante Posts: 2
    edited July 2010
    Thanks for the quick reply, Russ!
    Allright, then I suppose I can give it a shot! Thanks!
