Channel islands passive preamp plc1 mkii
doctorcilantro
I'm changing up my system and downgrading; I had this mainly for my wife and kids since it has a remote, but it also works very well with my main DAC.
I have the box here somewhere, remote, and of course the AC adapter which only powers the ALPS volume control since it is a passive. It's in great condition; these are STOCK pics though, (for now).
$580 shipped
$580 shipped
For Sale 2019:
Tortuga Audio LDR passive preamp
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Post edited by doctorcilantro on
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
iFi iDSD DAC, .5m UBS, iFI Gemini cable, Oyaide Tunami XLR 1.3M, Oyaide Tunami Speaker wire 1.5M, Beyerdynamic DT1990 headphones, PS Audio P3 power center -
His unit actually looks better than the stock pics. Recommended Polkie.engtaz
bump - price drop 550 shipped.For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
$510 shipped via Paypal Gift!
For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
final drop 475 shipped via Paypal Gift.For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
I'm interested in a passive pre. I wasn't able to find any detail on how this pre works though. Is it a ganged pot, transformer based, or resistor based?Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
I'd have to email them. I looked in the manual and there are no direct answers to the questions you have asked.
ManualFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Review of single stage
First, it uses a continuous wiper in the potentiometer, meaning that regardless of the volume setting, the number of solder joints in the circuit does not change. It is not stepped, meaning that you cannot easily come back to exactly the same setting once you turn the volume control knob. There are no capacitors in the input or output circuit, which means the impedance changes directly with the volume setting. However, some people rail at the thought of adding capacitors to the signal path. The inside of the VPC-1 shows a very simple layout (photo below).For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
I emailed CIAudio your questions and some others from other members; they replied:"PLC uses an ALPS Blue Velvet laser-trimmed potentiometer."
???For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
I got a CI Audio VPC 2 I believe (same as the one but with 2 outputs (the second can be variable or fixed)
damn good passive pre, and is my favorite preamp to use with the Carver Platinum Amazings when I set them up. I have a Promethius TVC as well, but there are things I like better with the CI Audio, 2 of which are center imaging and oddly enough, the bottom end is better.
IF I had a need for more inputs, I'd be all over this. this is a nice cheap way to try passive preamplification....and if you havent...you should.Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Thanks for the input!For Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Thanks for looking into it. I think I'm going to hold out for a transformer-based pre.Turntable: Empire 208
Arm: Rega 300
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
bumpFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
Is the plc-1 still available?
sorry soldFor Sale 2019:
Decware EL34 amp
Allnic H-1201 phono
Zu Union Cubes
