Sub EQ sytems
Polkie2009
So many of us are getting one or more subs here, I'm looking for info from others who already own or use some of the various sub eq systems out there(SMS-1,antimode 8033,SVS AS EQ1, BFD REW for a few). If you had to choose just one which would you prefer?
Post edited by Polkie2009 on
Check out the Behringer DEQ2496, 31 filters per channel all parametric. Has a built in RTA all you need is the Behringer EMC8000 Mic.
I went with the DCX2496 (it's a crossover with some parametric eq function, no RTA) and REW (that's an RTA). -
Depends on how much time you want to spend and money.
If you like to tweak and on the cheap then REW or if you want it now and no time then the SVS.
I had a HSU 3 3 and 2 MBMs and had great success with REW and the BFD.
Once I got my SVS PB13 I still used REW to figure out how to use its one filter.Speakers: SDA-1C (most all the goodies)
