Banana Plugs, to do, or not to do...??
lessthanzero
lessthanzero Posts: 31
edited September 2010 in Basic Hookup/Wiring Questions
Is changing the wiring of the speakers and amp from bare wire connections to banana plug really worth it? Some schools of thought indicate that bare wiring of both the speaker and amp is "more pure" and less prone to connection problems, however, the other school of thought is that the use of banana plugs facilitates "ease and speed" of connections, AND gives a better connection due to the physics of the banana plug itself. It seems that once you connect all of the wires it stays that way until an equipment change.
So, what say you.....??
Post edited by lessthanzero on
«13
  • gfong
    gfong Posts: 1,079
    edited July 2010
    I just did the whole Banana plug deal with my rig and I like the results. I can not comment on the sound quality + or - as I changed over to 14 gauge wire at the same time I did the plugs.
    I do know for me, it looks better, is neater and cleaner looking, easy to take out and hook up it I ever have to move things around and the connections are secure.
  • lessthanzero
    edited July 2010
    gfong wrote: »
    Thanks for that info. I am really thinking of starting this project. What type of banana plugs did you use? Some think the "sawtooth" is better than the "standard" type....?? It has been suggested that the locking banana plugs would be best....again????
  • Outfitter03
    Outfitter03 Posts: 563
    edited July 2010
    I recently did my speaker setup. For my Fronts and Centers I used 10 gauge Belden wire and these Nanners
    http://www.parts-express.com/pe/showdetl.cfm?Partnumber=091-330
    For my surrounds I used Monoprice 14 gauge and these Nanners from Monoprice.
    http://www.monoprice.com/products/product.asp?c_id=104&cp_id=10401&cs_id=1040115&p_id=2801&seq=1&format=2
    They both worked well. I used the side mount on the 10 gauge. It worked pretty slick. Sounds good to me and as I saw it a good way to start and I am not into this too much if I decide to later upgrade to manufactured cables.
  • Face
    Face Posts: 14,340
    edited July 2010
    I'd rather use bare wire, or tinned ends instead of cheap connectors.
  • fbm211
    fbm211 Posts: 1,488
    edited July 2010
    Yeah,
    Ya'll should get yourself some good pure copper or silver plated pure copper nanners.
    Furez makes some good ones at a reasonable cost.
    Better yet,get Eichmann silver bayonets if cost is not an issue.
    Me,I think Ill be upgrading from the Furez nanners to the Xhadow banana plugs.Most of all because of thier 3 type connection option.IE: Solder/Set screw/solder and set screw.
    Ill go with the set screw after reading about a potential loss of transperency using solder.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
  • jinjuku
    jinjuku Posts: 1,523
    edited July 2010
    While the monoprice banana jacks are cheap (as in money) they are also made cheaply. They entire body is made up of three parts. The issue is the tip screws in and has a propensity to loosen up. If they did a single piece top half body and tip then I could recommend them.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited July 2010
    Banana connectors are advantageous only for ease of switching. Properly tinned wires will give you fewers possible bad contacts.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • decal
    decal Posts: 3,205
    edited July 2010
    Try them and make up your own mind.After all,you are the one hearing your system not us.Just a thought.
  • lessthanzero
    edited July 2010
    decal wrote: »
    You are right in that fact, however, I really want to know the true value, or not, the use of banana plugs. Does using a banana plug make the source sound better, or not, or the same. Then, there are so many manufactures of the plugs, which would provide the best cost to benefit ratio. I don't want cheap, but I don't want to spend too much either.
    To all that have posted, thanks, I'm learning............
    pitdogg2 Posts: 27,199
    edited July 2010
    the only reason I ever use spades or nanners is to get away from the corriosion of the bare wire
  • gp4jesus
    gp4jesus Posts: 2,019
    edited July 2010
    If you never crank your system its likely you'll not notice the diff.
    Tinned ends are a small improvement.
    Either way, banana plugs have 10-100 times the surface area over the spring loaded clips that come w/ budget electronics* & speakers*. Its one of many places "they" save money @ the factory. That's why the better stuff* has 'em.
    *all connected w/Premiere ICs
  • hearingimpared
    hearingimpared Posts: 21,136
    edited July 2010
    Nanners - good ones. Mono price and Rat Shack are just too cheaply made.
  • greene1968
    greene1968 Posts: 126
    edited July 2010
    i like to run nanners..mainly to make it easy, but agree..the cheap ones suck
  • geebolt
    geebolt Posts: 215
    edited July 2010
    I added bananas to the equipment side of my speaker cable as others have suggested for ease of switching out. I left bare wire connections at the speakers. It definitely makes it easier to move or change components and I did not notice any difference in sound quality. And also as others have suggested, get good ones!
    George
    Fronts: Polk RTi A7's
    Center: Polk CSi A6
    Surrounds: Polk TSi500's
    Subwoofer:Polk DSW Pro 500, Emotiva Ultra 12
    Amplifier: Emotiva XPA-5
    Processor/AVR: Emotiva UMC-1
    DAC: Emotiva XDA-1
    CD player:Emotiva ERC-1
    Blu-Ray: Oppo BDP-93
    Turntable: Kenwood KD-500
    Tonearm: Polk-Mayware Formula 4
    Cartridge: Shure M97-XE
    Television: Sony KDL-55EX500
  • kawizx9r
    kawizx9r Posts: 5,150
    edited July 2010
    I personally use http://www.speakerrepair.com/mm5/merchant.mvc?Screen=CTGY&Category_Code=locking
    Just my personal preference. I don't like the thought of having bare wire hooked up to my speakers/amp, and I like that they're locking so they stay in place even if I picked my speakers up and moved them around.
    -Freddy
    Truck setup
    Alpine 9856
    Phoenix Gold RSD65CS
    For Sale
    Polk SR6500
    Polk SR5250
    Polk SR104
    heiney9 wrote: »
    Any clue how to use the internet? Found it in about 10 sec.
  • lessthanzero
    edited July 2010
    geebolt wrote: »
    George
    I was thinking of doing this just for the ease and security of the speaker wires at the receiver, with bare wire at the speaker end. There are a lot of folks who really do not like banana plugs and are huge advocates for bare wire only for the "pureness" of the wiring, then the advocates for banana plugs seem to mention the convenience of the use of the plugs during the changing, or working with, equipment, and I don't hear very much about sonic improvement. So, I may go half and half......
    To all who have posted, a huge "thank you" to you. I have learned quite a lot from your experience........
  • fx20
    fx20 Posts: 26
    edited August 2010
    I use Nakamichi plugs, they are available at http://www.nakamichiplug.com/product-0534E.html, they look nice, lighter than monoprice one, speaker cable stays in plug firmly. One downside of it is its unknown copper amount in the plug.
    By the way, there are claim as these banana plugs would improve your listening experience. Just go and grab the affordable ones. My $0.02.
  • lessthanzero
    edited August 2010
    fx20 wrote: »
    Thanks for that info and the link. I had read that the sawtooth banana plug was better than the "regular" type due to the fact that there is more of a surface contact. do you find that it stays firmly in the receiver? I was thinking of the locking type so it would not move if I were to pull the receiver off the shelf to make connections.
  • fx20
    fx20 Posts: 26
    edited August 2010
    I use them on my UPA-1s and RT55i, they fix firmly in them. The cables also stay firmly compared to monoprice's.
  • gp4jesus
    edited August 2010
    Naners also, as others said above, provide a tighter* connection than the spring loaded "BPs".
    * The locking type even more so
    Consider this: those spring loaders net you the surface area slightly greater than the edge of your finger nails.
    I've had 10 & 12 gage wire fall out of the spring loaders. That's never happened to me w/naners. Higher quality nanners=better connection.
    cheers tony
  • mole'
    mole' Posts: 3,160
    edited August 2010
    kawizx9r wrote: »
    -Freddy
    i like the idea of those plugs
    mole'
  • leadfoot1
    leadfoot1 Posts: 155
    edited August 2010
    I have bananas on all my surrounds and really like the convenience of them. I have had bare wire, bananas, and spades and have never noticed a difference in sound between any of them.
  • cstmar01
    cstmar01 Posts: 4,424
    edited August 2010
    personally it just makes it easier when switching stuff in and out IMO. Spades are what I like on the amp end, unless its an AVR then its a pain in the butt to work with.
  • polkatese
    polkatese Posts: 6,767
    edited August 2010
    After all of the problems dealing with tight spots in the back of my HT wall unit, nanners are the only option for me. Bare wire would be a disaster waiting to happen, and spade would be the same. Just don't have the clearance and reliability of nanners.
    I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie.
  • helipilotdoug
    helipilotdoug Posts: 1,230
    edited August 2010
    Recently I made a set of cables using locking banana plugs I got from Bluejeans cable.
    http://www.bluejeanscable.com/store/speaker/index.htm
    There are several brands that look exactly the same, and I have a feeling were all made by the same manufacturer in China. Pricing was fairly close, but the bluejeans price was the best. Anyway, they were easy to install, and seem to be of good quality. I had been using pins on a old set of cables on the mains for years, and bare wire for surrounds. The PITA factor made me search for a better way. I liked the idea of the banana plugs, and chose locking plugs for security. The quality of sound did improve quite a bit, but keep in mind I did replace the over 20 year old cables with heavier new cables, as well as going to the bananas. I am very happy with the way everything turned out using locking bananas,
    Sunfire Theater Grand IV
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
    http://www.douglasconnection.com
  • HB27
    HB27 Posts: 1,518
    edited August 2010
    I switch speakers like a woman switches shoes. Daily. Sometimes 3 or 4 times daily.
    I use 'nanners myself.
    I've used a lot of different types and a lot of high $ 'nanners.
    I bought the Nakamichi which I can see no difference in the "collapse" factor. Not acceptable.
    The upper end Monster. Not acceptable.
    Parts Express many types. Not acceptable.
    AQ Not acceptable.
    And many of the "On Sale" bags of them.
    I haven't tried all types but what i did find acceptable were some "PRO" 'nanners from IRC music here on the southside of Indy.
    They have a PRO intatllation guy. "Joe". Joe makes up snakes, and all kinds of cables for pro applications.
    I bought 4 'nanners from him about 5 years ago. They look like the plain jane silver taiwans but they've never lost tension and they've never backed off where the set screw holds them in place. They ARE silver and quality. I can only buy them as the Double Nanners and they're $5 each now.
    I went back and bought 20 more of them after I saw how well they worked and the tension factor.
    Use the silver and see if you have a pro shop around that makes up cables for concerts, shows, etc.
    Banana plugs can be very convenient but can cause problems too with connections backing off and losing tension.
    The pro plugs I scored are the only ones I'll use with my tube gear connections.
    nooshinjohn Posts: 25,973
    edited August 2010
    fx20 wrote: »
    It is an absolute tragedy that the great Nakamichi name has been reduced to this...
    Not saying anything about their connectors, rather that to fall from building some of the most sought after and respected gear in the world to being purveyors of interconnects and banana plugs is one hell of a long way to fall.
  • helipilotdoug
    edited August 2010
    John, I read somewhere, that Nakamichi does not make baqnana plugs. I saw it on some website somewhere. The author showed a email to him from Nakamichi saying they never have made any banana plugs, and if you see them, they are rip offs. I'll try to find that web page and post the link.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • HB27
    HB27 Posts: 1,518
    edited August 2010
    I've got some here that have Nakamichi logo's all over them. I'll see If I can find them and post pics. Bootlegs....I wouldn't doubt it. They're pretty cheap.
    edited August 2010
    I would not doubt it... not to derail here but that the brand has fallen so far as to not be able to take down the fraudsters is just as bad. I loved the old Nakamichi gear.
