Which Kind of Plugs for Monitor 7/5?
Assimilator87
Assimilator87 Posts: 20
Hey guys, I recently acquired some Monitor 7Bs and 5Bs and I was gonna use the 12AWG wire that I have, but the hole in the binding posts is way too small, much smaller than the SDAs. So I was wondering if I'm supposed to use banana plugs for these or something else?
Thanks everyone
Polk SDA 2B (Pin/Blade) - Front L/R
Polk SDA CRS+ (Blade/Blade) - Center
Polk Monitor 5B - Rear L/R
Onkyo TX-SR805 - Receiver
Carver TFM-35 - Amplifier Front L/R
12 AWG Monoprice Speaker Wire
Blue Jeans Cable Belden F2 HDMI
Post edited by Assimilator87 on
  • kcoc321
    kcoc321 Posts: 1,788
    edited July 2010
    Banana plugs will work, or upgrade the binding posts and you can wire direct.
    F1nut Posts: 51,763
    edited July 2010
    You should be able to use bananas or spades. Never use bare wire.
  • Assimilator87
    edited July 2010
    Cool thanks. I ordered the side entry ones from Monoprice, but I was a jackass and only ordered two pairs instead of four *face palm* Also, why don't you recommend bare wire?
