Sonic Barrier BlackHole in my SDA 1C's
13
  • george daniel
    george daniel Posts: 12,096
    edited July 2010
    I'll just say this,, my 1C's sound like a much larger speaker,(SDA)
  • Face
    Face Posts: 14,340
    edited July 2010
    Good, I don't feel bad anymore. :)
    Toolfan66 Posts: 18,018
    edited July 2010
    Face wrote: »
    Don't I feel the same way with my 1C's.... ;)
  • brgman
    brgman Posts: 2,859
    edited July 2011
    Dredging up this old thread i am under the impression that if i put BH5 just behind the Mids and tweets on the upper 2/3 of 2.3tl's i will see improvement.Staying away from the bottom 1/3 at the PR is recommended.
    I would also replace the batting in the upper end as well?
    I’M OFFENDED!!!!
    edited July 2011
    IMO that is the only way to place it, just behind the mids and tweeters the clarity in the highs is fantastic!! Don't do the whole cabinet!!!
  • brgman
    brgman Posts: 2,859
    edited July 2011
    Great.Thanks!
    I’M OFFENDED!!!!
  • headrott
    headrott Posts: 5,496
    edited July 2011
    Larry, if I remember correctly, you said that the Sonic Barrier Blackhole was better suited in your 1.2TL's? I don't remember where I read that a while back, but could you let me know if this is correct? That the Blackhole material was better siuted in your bigger 1.2TL's than the 1C's (due to the size of the speakers)?
    Greg
    P.S. I just read the thread and realised that it is not as good in the bigger SDA's. Sorry for the useless post. I had it opposite.:redface:
  • george daniel
    edited July 2011
    I used the Blackhole/Sonicbarrier in my 1C's,,BH on the bottom/back--SB on the sides--still have it in them.The only thing that I've noticed other than previously stated,is that I'm able to to hear a tad better bass than before.I'll defer to Larry,since he was the first to do this,,so Larry,whats your current status and opinion with your 1C's?
  • Joe08867
    Joe08867 Posts: 3,919
    edited July 2011
    I have Sonic Barrier behind and to the sides of the mids and tweeters of my SDA2's, and I was amazed at the bass response. It seemed to help with attack where the SDA2's seemed to be a bit sloppy for my taste.
    I started with the barrier just on the rear of the cabinet but on a whim I decided to try the side walls up top and that made the biggest difference.
    This was on SDA2b's.
    On my original SDA2's the dual tweeter version, the sonic barrier choked them up. I used dynamat on them. Full coverage on the back and an x patter on the sides.
  • dorokusai
    dorokusai Posts: 25,576
    edited July 2011
    I agree. If you do the whole cabinet you'll make the speaker dead. It's best to try and not overdo things when you're modding and tweaking....but this crowd is known for overdoing it. In my CRS+ I only did the sides.
    edited July 2011
    dorokusai wrote: »
    Agreed!! and I over did it IMO!! George I trimmed everything back in my 1C's and I like what I hear much better then before.. I am working on my CRS+'s now and I did what Mark did and just did the sides.
    This was a costly mistake on my end, do a little at a time and go from there, it is a worth while tweek but use it sparingly..
  • brgman
    brgman Posts: 2,859
    edited July 2011
    I see PE no longer sells teh BH5.Should i pay the premium and get this from speakercity or just use sonic barrier?
    I’M OFFENDED!!!!
    edited July 2011
    BH5 can be had at Sonic Craft, but Sonic Barrier works well too and is cheaper..
  • george daniel
    edited July 2011
    Add me to the list of "overcooked",I've got to install the tweeter rings this weekend,,and I think I'm gonna remove some of the SD/BH that I so generously applied.
  • dorokusai
    edited July 2011
    Yeah George....its easy to do and you're not alone as I only know by experience as well. You can get lost in the fact that everything MUST benefit and be better than before idea....and it just isn't that at all. There's no one here that thinks they know more than Polk BUT the knowledge base here is solid.
  • drumminman
    drumminman Posts: 3,396
    edited July 2011
    I read with interest your earlier posts about the improvements you were hearing, and now this. I'm thinking about doing some version of this to my 2.3TL's.
    Thanks,
    Fred
  • george daniel
    edited July 2011
    Fred-- actually two things--first was the bass,,(did not seem right),,I thought it was the Adcom GDA,, so I removed it from the chain,,and after some recent listening,,something just did not seem/sound right,,and after reading Larry and Mark's posts,,I think they are right,,cabinet overdone--for me the 1C's just seem a little subdued,,,and yes,,initially I thought they were GREAT,, then only over time,it seemed like they were missing some sparkle/dynamics. I'm gonna remove the SB/BH from the sides/bottom to start with and go from there.Looking back,, what appeared to be better,,was just different,, not necessarily better.
  • drumminman
    edited July 2011
    From what I've gleaned on this forum, the optimum placement is the wall directly behind the MW's and tweeters. Sidewalls, maybe. Definitely not in the area occupied by the PR.
    Sounds like you and Toolforlifefan confirmed this.
    edited July 2011
    That is correct and the back wall behind the drivers does not need to be covered either just some nice strips works very well, and IMO none behind or around the PR..
  • Joe08867
    edited July 2011
    Never behind the PR. It just kills the low-end. Learned that the hard way.
    edited July 2011
    Joe08867 wrote: »
    Ditto!! The money I wasted on BH5 and SB makes me sick :eek: More is not better all the time..
  • george daniel
    edited July 2011
    +1 I'm removing the BH behind/below the PR--I'll report back.Gotta love this hobby.
  • thsmith
    thsmith Posts: 6,082
    edited July 2011
    Have not reads the entire thread but do you also remove the OEM batting when you do this?
    TIA,
  • drumminman
    edited July 2011
    do you guys recommend one over the other, Black Hole vs. Sonic Barrier?
  • george daniel
    edited July 2011
    IIRC the SB was much less expensive than the BH
  • dorokusai
    edited July 2011
    I use Sonic Barrier on electronics instead of Dynamat and Black Hole on loudspeakers.
  • brgman
    brgman Posts: 2,859
    edited July 2011
    dorokusai wrote: »
    Where or how do you use the SB on electronics?:confused:
    I’M OFFENDED!!!!
  • dorokusai
    edited July 2011
    On the chassis. Top, bottom and side panels. I've been using it, along with Dynamat, as a pretty much standard tweak for every piece that I've owned or sold for years. I'm almost out of SB so I may use that reason to try the Cascade VB-2 brand next.
  • brgman
    brgman Posts: 2,859
    edited July 2011
    may have to try that.thanks:biggrin:
    I’M OFFENDED!!!!
  • george daniel
    edited July 2011
    Whew-- well,,I just pulled out the "barrier",,most of it anyhow,,left the barrier behind the mid-drivers,and a little on the upper sides,and I'm gonna have to admit(yep,,I'm not too big to say it),,I overdid it,,,Mark and Larry are spot on--too much,as in my case just kills it,,,what am I hearing,,more "life" to the music(no pun intended)and a much less subdued sound.Lesson learned,,more is not better.:smile:
