DIY Flexy Rack
tryrrthg
tryrrthg Posts: 1,896
I know, you've seen one flexi rack you've seen them all, but you haven't seen MINE! :D
it's MDF covered in Parts Express cherry vinyl. It came out looking pretty nice. I finally got the hang of putting on the vinyl on the last two shelves so there are some mistakes on the other shelves. I made it for about $60 so I can't complain. I love the look, especially with the gear in it. And the wife even approved!
Note: I'm probably selling the Audio Research preamp if anyone is interested. I hate to get rid of it, the cool factor is VERY high, but it just doesn't work with my amp. :(
  • Wardsweb
    Wardsweb Posts: 942
    edited December 2003
    Nice job. Here is mine done in 3/4" birch veneer panaply.
  • gidrah
    gidrah Posts: 3,049
    Nice rack. Trust me if I ever build one (and buy a digital camera), you'll see more than one picture of it.
    ? Is it just the picture or are the top shelves leaning? I'm thinking it's just in the picture.
    ?#2 Why isn't the pre "working" with you amp?
    Make it Funky! :)
  • Ron-P
    Ron-P Posts: 8,520
    Nice looking Flexy's! I just finished up one myself. Took all my gear off the wall rack and built a 3 shelf'er.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • tryrrthg
    Thanks guys!
    Answer #1: it's probably me taking a slanted picture. The rack is indeed level! :D
    Answer #2: The McCormack amps have a high gain, designer Steve McCormack designed the amps to be used with passive preamps or pre's with little gain. The Audio Research pre is also high gain, it has 18db of gain. Putting the two together just didn't work. With the AR pre I couldn't make it to "9 o'clock" on the volume knob because it was so loud. With other amps this would not be a problem...
    The McCormack pre (on the top shelf) is a passive pre. it has a passive and buffered outputs. The buffered just gives the signal a little "boost" (or so is my understanding) to the signal so it can run long IC's or amps that need a little more drive from the pre. Both pre's sound GREAT! but the McCormack pre gives me a LOT more volume options!
  • gidrah
    gidrah Posts: 3,049
    Thanks for the quick reply. I fully understand what you mean.
    Nice rack and nice rig.
    Make it Funky! :)
  • tryrrthg
    Thanks! it's nice to finally have the rig "complete" enough for me to enjoy! The only thing left: The bottom octave! I can't wait!
  • Tour2ma
    Tour2ma Posts: 10,177
    What are the columns? All-thread with SS tubing as spacers?
    More later,
    Tour...
    Vox Copuli
  • hotwheelman
    hotwheelman Posts: 1,300
    Wardsweb, Are those koss m80's atop those speaker stacks?
    "Its worked so far but we're not out yet."
    "Hey big man let me hold a dollar"
  • RuSsMaN
    RuSsMaN Posts: 17,985
    You guys rock.
    I can't build ANYTHING. I tried to build a 4-shelf flexy for the mancave some time ago, a COMPLETE and utter failure. It's so 'wobbly', I ended up throwing it the master bedroom closet, and buying a Lovan. The wife uses the flexy as a shoe rack now.
    Cheers,
    Rooster
  • Wardsweb
    Wardsweb Posts: 942
    Nope, from the top
    Garrard about 15 years old
    Design Audio PS6 - oops my bad, Design Acoustics
    BIC Model 66
  • RuSsMaN
    You mean Design Acoustics PS6 - I've got a pair in the closet missing a tweet in one.
    I'll bring em to the gathering if you want em' for parts. I've also got the Literature SOMEWHERE if I can find it.
    Cheers,
    Rooster
  • tryrrthg
    Originally posted by RuSsMaN
    You guys rock.
    Cheers,
    Rooster
    This might sound like a dumb question but did you drill the holes the EXACT same size as the threaded rod?
  • tryrrthg
    not sure if this was directed at me or not, but no, that's just threaded rod as the columns, my digital camera isn't high tech enough to pull in that kind of detail...
  • RuSsMaN
    What do you think? The answer is *no*, never even crossed my mind until I was tightening the final nuts.
  • Tour2ma
    not sure if this was directed at me or not...
    Yes, it was... thanks.
    Had almost forgotten a rebuild of a 100' tall, trayed distillation column a decade or so ago... all-thread and spacers all the way...
    More later,
    Tour...
    Vox Copuli
  • TheMaster
    TheMaster Posts: 184
    Thyrryg, you did a nice job on that flexi rack. I've been wanting to replace my rack but I don't think I will spend a couple hundred $$ for it. Could you tell what you used (size of bolts, thickness of the vinyl, ideal length and width of the vinyl and places to get a rod). I think I can put one together but, I need some pointers that will help me with building and fabricating it.
    Thanks,
    Glenn
    HT:
    DENON AVR-3803
    DENON DVM-1805
    SONY DVP-NS300
    SONY 36' HDTV Wega
    ADCOM GFA-555
    ADCOM GFA-555
    ADCOM GFA-2535
    ADCOM ACE-515
    POLK RTi70's (Bi-Amped)
    POLK CSi40
    POLK FXi30's
    POLK RTi38's
    POLK CSi20
    POLK PSW 450
    SVS PB2 Plus
    2 CH Stereo:
    AudioSource Pre/Amp 1
    Hafler DH-500
    Sony CDP-CX235
    Monster Cable HTS3500
    SDA SRS 2.3tl
  • shack
    shack Posts: 11,154
    Here is a site that has a 3 leg version:
    http://www.tnt-audio.com/clinica/flexye.html
    or four legs:
    http://www.jetcom.org/~jsb/flexirack.php
    others may have some links to sites that may help.
  • tryrrthg
    Thanks,
    Glenn
    Thanks Glenn!
    The most expensive thing about the flexi was the vinyl. It came from parts express. Here is a link to their vinyl covering. You can see the different colors at the bottom of the page and the next page. Covering the MDF was a bit tricky. I tried wrapping one piece around all the corners so that I didn't have to try and cut straight edges, etc. If you can wrap it tight enough it looks pretty good. I needed 2 rolls to cover 6 shelves (I only ended up using 5 because I didn't get the vinyl tight enough on one of the shelves).
    I used 1/2" threaded rod. I wanted to use 5/8" but they only had 3 rods at the store and they were all pretty banged up. I think the thicker rod looks MUCH cooler!
    When drilling the holes you want to try and drill through all the shelves at the same time so all the holes line up. So its good to have some big clamps laying around. Also take note from Russman, you want to drill the holes the SAME size as the threaded rod, meaning I drilled 1/2" holes for 1/2" rod.
    I made my shelves 24" wide by 17" deep out of 3/4" MDF. I went 17" deep because my amp is pretty deep. I wish I had gone 16" instead... You'll have to measure how deep your equipment goes to figure out the best dimensions for you.
    That's all I can think of now. Let me know if you have any questions. It was a fun project and turned out GREAT! My wife even thinks it looks good!
  • tryrrthg
    oops screw up on my part...
  • Wardsweb
    Wardsweb Posts: 942
  • Wardsweb
    Wardsweb Posts: 942
    Pic sent to me by others who have built my rack
    Les' rack
  • Wardsweb
    Wardsweb Posts: 942
  • Wardsweb
    Wardsweb Posts: 942
    Dustin's Rack - just goes to show the flexibility of the design. You can lay it out any way you want.
  • RuSsMaN
    I noticed one thing Wards, no mention of Neoprene washers?
    During my 'attempt' at a flexy, I had a Neoprene washer on each side of the shelf, between the wood and metal washer. I've seen a few others take this route too.
    Cheers,
    Russ
