Carver CT-3 vs Denon 3300
broncsrule21@
broncsrule21@ Posts: 113
edited July 2010 in 2 Channel Audio
Would the Carver CT-3 pre/tuner provide a better 2 channel experience over the stereo/pure direct section of a Denon 3300? from what I have found so far this particular Caver model is on their low end of the spectrum. I can pick one up for less than $89 bucks at a pawn shop. Cosmetically it is in pretty good shape.
HT-- Denon avr-2808ci,Emotiva UPA-1s, RTi 10's, CSi A6, ERD-1 surrounds, Vizio P50, Yamaha yst-sw300, DVR hr21, 40g PS3, APC-h15
Downstairs-- Denon avr-3300,Emotiva UPA-2, Toshiba 50" rear projection, Denon 2200 sacd, Emotiva ERM-1s, small Yamaha sub
Post edited by broncsrule21@ on
  • thuffman03
    thuffman03 Posts: 1,325
    edited July 2010
    The CT-3 was one of the lower models of preamps that Carver made. It is good but there are much better ones that I would suggest.
    C-1 Very nice pre
    C-11 Same as the C-1 but a few updates
    C-5 Had this one, great for a two room setup.
    C-6 Very good pre. Best IMO until you get into the tubes and the C-19
    C-16 Same as the C-6 but with different face plate.
    C-19 Currently running this. Great tube/SS pre. Hard to find for under $800
    BTW, $89 is a pretty good price for the CT-3. Does it have the remote?
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • broncsrule21@
    edited July 2010
    no remote, unfortunately
    billbillw Posts: 7,534
    edited July 2010
    Really depends on the source. The Denon 3300 was actually a very nice sounding unit with warm Analog Devices DACs in it. I still use one in the bedroom. If you are sending a digital source via optical or dig coax, then you are probably better with the Denon. If you are sending analog signals, then it may not be optimal.
  • broncsrule21@
    edited July 2010
    billbillw wrote: »
    Its funny you mention that. I actually prefer the sound from my Denon 2200 via optical than the analog connection. Thats why I was wondering if adedicated pre would help.
