Wanting A New Tube Amp!
AudioFilet
AudioFilet Posts: 235
edited July 2010 in 2 Channel Audio
New used one anyway.
My experience with tube equipment is pretty limited though, so therefore the request for help. I really like this one here:
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=110485495474&ssPageName=STRK:MEWAX:IT
But the price seems like a bit much?? But then again, I just don't know if it is or not. Any help would be much appreciated. What I have for speakers is a set of NHT Classic 3's, and I would like to use a Yamaha 12" passive sub running through a Dahlquist passive xover. Or, with this amp I guess I could just hook the sub up to the center channel output. I also have a set of RTiA3's I could use instead of the NHT's.
2 Channel rig:
LSi9"s (modified xover's) & HSU Sub
Harman Kardon HK 990 Amp
Onkyo C-S5VL SACD
Music Hall MMF 5.1
Furman Elite 15
HT rig:
HK AVR-745 & Polk Monitor Series
Post edited by AudioFilet on
    edited July 2010
    We'll have to wait for the old-time TUBE boys to weigh in on this because I'm just beginning to hear various tube amps. Most of them Chinese..since that's where I've been for the last 12 months!
    But this guy sounds 'interesting' to say the least and he's not that far from my neck of the woods....may give his 'stores' a visit when I return.
    Good luck with your decision...actually a good 35 w/channel tube amp can supply some decent power to the speakers you list above. You'd be surprised.
    cnh
  • HB27
    HB27 Posts: 1,518
    edited July 2010
    As a PREVIOUS EICO ST-70 owner of THREE of these integrateds I can tell you a bit about them.
    OF ALL the tube amps I've owned they're my least favorite. Though nice sounding they leaned more to the SS side than tube in sound quality.
    They're weak in the pre section, loudness switch mods are a must, and they're constantly wanting new solder connection touch ups. JMHO.
    They wouldn't be my first choice IF I were wanting to get my feet wet into tubes.
  • george daniel
    george daniel Posts: 12,096
    edited July 2010
    My first tube amp was an ASL ,,the small monoblocks,, thats where I started learning about biasing and tube rolling,,if it were me,,I'd look for an Anthem Amp 1,,maybe some older VTL gear,,or a Quicksilver GLA,,each has the "sound" that they are known for,and are well built,affordable,relatively simple,,and won't break you when tube rolling--good luck.
    here's a couple
    http://www.audiogon.com/cgi-bin/cls.pl?ampstube&1282400620&/Antique-Sound-Lab-Typhoon-DT-S
    http://www.audiogon.com/cgi-bin/cls.pl?ampstube&1283269438&/Dynaco-St-70-Violet---Black-te (contact/talk with Mr Vincent,,if you need references,,pm jerryj12)
    mhardy6647 Posts: 35,015
    edited July 2010
    HB27 wrote: »
    I would concur with the above. I actually have an ST-40 (an extremely similar but "detuned" compared to the ST-40) in the basement awaiting restoration... virtually all amps using 7591 outputs tend towards a more sterile presentation, I'd opine.
  • markmarc
    markmarc Posts: 2,309
    edited July 2010
    Zero wrote: »
    Hello AudioFilet,
    Careful, once you stumble across a real good tube amp, returning back to a conventional solid state amp may be difficult. :D As a first tube-timer, I'd suggest keeping things as simple as possible for now. Here are a few things that I'd suggest considering while in search for a new tube amp.
    - Because you intend on powering conventional loudspeakers of average impedence and efficiency, you will likely want to step into a tube amp that boasts a solid 30wpc or more.
    -Try to choose a tube amp that uses a more common set of power tubes, such as KT88 or EL34 based tubes. These tubes are easy to find and can be relatively affordable. Starting off with a super exotic piece may seem cool, but that coolness factor will quickly end when you have to search/flip the bill for replacement tubes.
    - Although the China Fi stuff on ebay can be real tempting, there is a lot to be said for product support. Since this is your first time, I'd suggest keeping to the more established brands that have a good infrastructure in place just in case you require help and/or service on your tube amp. Here are a few brands that meet the above criteria: Rogue, Prima Luna, Joilda, Antique Sound Labs, Eastern Electric, Vista Audio, Pathos, Cayin, - to name a few. All of the aforementioned brands offer relatively affordable tube amps that carry a great reputation in sound quality, service, and reliability.
    Other Suggestions:
    If I were in your position, I'd narrow down my search to Prima Luna and Vista Audio. Although this is largely based off of personal bias, here's why I'd lead you towards those two brands..
    Prima Luna Prologue 1: Just one look at this piece, and you'll know that it's solid. Hefting it in the air will only confirm what your eyes tell ya. This is a great all around piece that embodies the whole 'tube warmth' that so many ears get wet for. It is more than powerful enough to drive your speakers so power should not be much of a concern. More importantly, their products are very well made, is backed by a strong deal/distribution network, and features an auto biasing circuit that really takes out part of the hasstle of tube ownership. In case you aren't familiar with what auto-biasing is.. it is a circuit in the Prologue 1 that automatically adjusts its bias whenever a new tube is put in place. This means that you wont have to go in and manually adjust the bias every time you need to replace a set of tubes.
    Vista Audio i34: It's not nearly as pretty as the Prima Luna piece, and the brand is fairly obscure. The amps are made in Serbia and then given the ole' quality control check in NYC. I like this piece because its well made and sounds great. In fact, I'd even go so far as to say that as of this moment, its the only budget piece south of $2000 that I could see myself living with... tube or solid state. It's got a top to bottom balance/linearity that every tube amp should have (IMHO), without sacrificing that little bit of blossom and bloom that make tube amps so fun to listen to. Fantastic piece. Great support, and for $980, I've yet to stumble across anything better. (ps, if you do go with this piece, be sure to get the low-gain version).
    Alright, it feels like I typed up a book, so I will draw this post to a close. I haven't proof read anything so if this reads like ****, I apologize in advance. :) Good luck!
    Zero beat me to it...The Vista Audio i34 fits right in with your price point. Unlike most budget int. tube units, the i34 isn't too tubey gooey sounding. I bought one to be my reference tube amp. Boris is a great guy and takes excellent care of his customers.
    Former Staff Member TONEAudio
    2 Ch. System
  • reeltrouble1
    reeltrouble1 Posts: 9,312
    edited July 2010
    If you are going to be into tubes then skip over the entry and get something from vtl, manley, bat, cj, or the mentioned ASL, you will save in the long run and enjoy your sound for longer, if you just want to fool around with it a bit then there is plenty of entry stuff, entry is entry and nobody likes their baby called ugly, I had an origingal Manley Stingray without the i-pod thingy that was very sweet and can be had for a bit more than your talking price-point, its your choice so whatever you decide enjoy and oh
    Tubes Rule.
    RT1
  • AudioFilet
    edited July 2010
    Wow, thanks for all the help. I am attracted to that Vista Audio i34 amp in particular. I downloaded the manual for it and it seems to fit the bill, and the price is right.
    I do have a tube amp now, a Chinese job called a Music Angel, using 4 KT88 tubes. I have upgraded the tubes in it from the original Chinese tubes, and it seems to sound better, but nowhere as sweet as the Fisher I once had.
    I have heard of people modifying these Chinese amps to greatly improve the sound. Anybody heard of this going on??
    2 Channel rig:
    Onkyo C-S5VL SACD
    Music Hall MMF 5.1
    Furman Elite 15
    HT rig:
  • Hawkeye
    Hawkeye Posts: 1,313
    edited July 2010
    I had about a 2 weeks of tube amps. Had two McIntosh 275 mk4's to compare with the 501 SS at the same time. The 275's with the stock chinese tubes were heavenly!! I went with with 501 SS for one reason. I wouldn't be tempted to roll tubes.
    I went with a tube pre instead. Not saying I'm right, I just couldn't trust myself from spending an equal amount on tubes as I did on the amp. Tubes rule, no doubt. I like to think this way: I have short arms and deep pockets.:D
    Gordon
    2 Channel -
    Symposium Rollerblocks 2+ (16)Black Diamond Racing Mk 3 pits (8)
    edited July 2010
    Tubes Rule.
    RT1
    That's what we like to hear! Might want to consider a 'tube primer' for new tubies? Just a thought...but the above goes a long way in suggesting entry points.
    Thanks,
    cnh
    edited July 2010
  • zingo
    zingo Posts: 11,258
    edited July 2010
    My first tube amp was a DIY kit, and it sent me diving head first into the tube world. I'm really glad now that my first tubes I had to build myself as it provided me with an understanding that I would not have received otherwise. Just some words for thought... :)
    edited July 2010
    zingo wrote: »
    Lots of options at all price points. Personal faves, if cost is a primary consideration and the safety and well-being of pets or small children isn't :-)
    http://www.s5electronics.com/thome.html
    In all seriousness, we built one of their early 11BM8 push-pull stereo amp kits, and its sonic performance is quite respectable. Placed in a proper enclosure (with a see-through smoked plastic front to see the tubes glow), it did college dorm-room stints with both of our kids and was much liked for its sound and style.
  • zingo
    zingo Posts: 11,258
    edited July 2010
    I have to politely disagree. :) Building one of the S5 kits was a lot of fun and a good learning opportunity, but the time and money spent upgrading it there after was not worth it sound quality wise. I learned a lot, but ended up having to sell it because I just could not get the sound quality to where I wanted it, and the tubes aren't anything special either; 5670 triode and 6005 pentode tubes.
    The best DIY option I've seen so far is the Suppo Audio EL34 Commander. It does come from China, but customer support is good, and the kit comes with everything including tubes and case for $220 + $155 shipping. I have one hooked up now, and at 35wpc PP EL34, it will drive almost anything, and sounds great also.
    edited July 2010
    Point taken, but we probably don't really disagree; my data point is the earlier amp using the 11BM8 - which is essentially a 6BM8 with an 11V heater for series-string applications. Teh 6BM8 has a well-established hifi pedigree, especially in Japan. The amp I built is perfectly good sounding, and dead quiet as well, for the $140 price of the bare-bones kit at the time.
    The Amp using the 5670 and 6005 has not been heard by me.
    The EL34pp stereo amp looks quite nice - although the price with shipping is getting into the realm of a restored vintage integrated.
  • zingo
    zingo Posts: 11,258
    edited July 2010
    It was a very good learning experience, and they do offer quality parts for cheap, but I just couldn't get the sound quality good enough or noise low enough to keep me happy.
    It is a very nice kit with quality parts, but I would take it any day over a vintage integrated. I just don't have many feelings for nostalgia, and a new amp with quality parts is my cup of tea.
    I've attached my article on Suppo Audio EL34 amp for the read if anyone has free time. It's a neat little amp with big sound.
