wall treaments
gmorris
gmorris Posts: 1,179
edited December 2003 in 2 Channel Audio
I need to get some wall treatments for my listening room. Here is my idea.
Take a piece of the acoustic foam (http://www.partsexpress.com/pe/pshowdetl.cfm?&DID=7&Partnumber=260-516&ctab=7) and cover it with grill cloth, then hang it on the side walls in the 1'st & 2'nd reflection points. Does this sound like a good idea?
Bob Mayo, on the keyboards. Bob Mayo.
Post edited by gmorris on
  • Ron-P
    Ron-P Posts: 8,516
    You can also go to your local Home Depot and pick up a sheet of stiff-board insualtion and wrap that in cloth.
    Peace Out~:D
    If...
    Ron loves a film = don't even rent.
  • gmorris
    What is that?
  • Phil Dawson
    Phil Dawson Posts: 288
    There are two issues here. Absorbsion and diffusion. Are you trying to daden the room, cut down on reflections, or cut down on standing waves? Just hanging "something" on the wall could have either posiitive or negitive results if you don't know what you are doing. Some research might not be a bad idea.
    Good Luck,Phil
  • Tour2ma
    Tour2ma Posts: 10,177
    Spot on Phil...
    More later,
    Tour...
    Vox Copuli
