Different materials
Systems
Systems Posts: 14,872
edited December 2003 in Custom Fabrication
will different thickness' of mdf in a box affect sq or performance of the sub?
ex.
(2) 1.5" sides <---diff.
(2) 0.75" sides
(2) 0.75" front & back
thanks
Testing
Testing
Testing
  • [Deleted User]
    [Deleted User] Posts: 763
    edited October 2003
    Not at all. As long as the interior dimesions stay the same as to preserve the proper box volume, it will be fine.
  • delvryboy
    delvryboy Posts: 62
    ex.
    (2) 0.75" sides
    thanks
    it can when you start to get into heavy drivers, lots of power and enourmous enclosures.....flexing can cause some major sq and spl problems....but for the daily driver....3/4 MDF is perfect:D
    Post ****
    2003 MECA M2/MR2/DB1 IL State Record Holder/Champion
    CarAudioForum
    SoundIllusionsNetwork
    CarAudioTalk
